[GRASS-user] r.in.gdal/HF2/HFZ problem
I’m running grass 6.2 and I’ve updated gdal to version 1.8.1 in order to import HF2/HFz files into grass
%r.in.gdal -f
Supported Formats:
XYZ (rw): ASCII Gridded XYZ
HF2 (rw): HF2/HFZ heightfield raster
OZI (ro): OZI
So it should work… but:
%r.in.gdal ‘input=/path/to/HFZ/5m_irish_sea.HF2’ output=test title=test
ERROR 4: `/path/to/HFZ/5m_irish_sea.HF2’ not recognised as a supported file format.
I really don’t want to update grass as version 4.7 of proj that grass 6.4 requires doesn’t support general RSO projections and I am trying the reproject the HF2 file into that projection.
Any help would be greatly appreciated.
Could I use “gdal_translate” to change the HF2 to a TIF and then use r.in.gdal??
Garret
Dr. Garret Duffy
______________________
Department of Earth and Ocean Sciences
National University of Ireland, Galway
University Road
Galway
IRELAND
Office: +353 (0)91 492169
Fax: +353 (0)91 750533
On Fri, Oct 28, 2011 at 5:21 PM, Duffy, Garret
<garret.duffy@nuigalway.ie> wrote:
I'm running grass 6.2 and I've updated gdal to version 1.8.1 in order to
%r.in.gdal -f
Supported Formats:
OZI (ro): OZI
%r.in.gdal 'input=/path/to/HFZ/5m_irish_sea.HF2' output=test title=test
ERROR 4: `/path/to/HFZ/5m_irish_sea.HF2' not recognised as a supported file
format.
Is it really "/path/to" ? I guess not - if the real path contains white space
it may cause troubles in GRASS 6.2. We have fixed such cases in GRASS 6.4.
Please post the real path you have to better understand the problem.
I really don't want to update grass as version 4.7 of proj that grass 6.4
requires doesn't support general RSO projections and I am trying the
grass 6.4 requires proj 4.7? The test in configure is:
    if test `expr "$proj_ver" \< 446` = 1 ; then
        AC_MSG_ERROR([*** PROJ.4.4.6 or later is required.])
    fi
which is way older than Proj 4.7.
**Could I use "gdal_translate" to change the HF2 to a TIF and then use
r.in.gdal??**
Yes, this would be an alternative.
%r.in.gdal -f
Supported Formats:
OZI (ro): OZI
format.
fi
r.in.gdal??**
I'm afraid not, because the above error starting with "ERROR 4:" is
issued by gdal, not grass. Therefore any gdal program will report the
same error.
I noted some strange single quotes in the above r.in.gdal command.
Can you try
r.in.gdal input="/path/to/HFZ/5m_irish_sea.HF2" output=test title=test
instead of
Although I don't think this really helps...
Markus M
Thanks for the useful suggestions especially the M. Metz's "ERROR 4" info
The double 's were due to my typing.
I still get the "ERROR: 4..." message when I copy the file to the working directory.
However, when I **changed the file extension from HF2 to HFZ**, gdal_translate successfully converts it to a TIF. r.in.gdal *also* works to import it, had to run r.null and r.colors on it to recover the NULL values then everything was fine.
I take the M. Neteler's point about the version of PROJ... I will now try installing GRASS 6.4 with my RPM installer and DE-selecting the latest version of PROJ to be installed (since I already have 4.5.1 installed)... does this make sense/is this possible?
Garret
-----Original Message-----
From: Markus Metz [mailto:markus.metz.giswork@googlemail.com]
Sent: 31-Oct-11 8:33 AM
To: Markus Neteler
Cc: Duffy, Garret; grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] r.in.gdal/HF2/HFZ problem
%r.in.gdal -f
Supported Formats:
OZI (ro): OZI
So it should work... but:
title=test
white space it may cause troubles in GRASS 6.2. We have fixed such cases in GRASS 6.4.
6.4 requires doesn't support general RSO projections and I am trying
fi
use
r.in.gdal??**
I'm afraid not, because the above error starting with "ERROR 4:" is issued by gdal, not grass. Therefore any gdal program will report the same error.
Can you try
r.in.gdal input="/path/to/HFZ/5m_irish_sea.HF2" output=test title=test instead of r.in.gdal 'input=/path/to/HFZ/5m_irish_sea.HF2' output=test title=test ?
Markus M
