I think there was a recent thread on *.in.lidar modules, but I paid no
attention as I'm not currently using lidar data.
After checking out the latest from the grass7_trunk svn repository I
configured the source tree and tried to build it. There are errors in the
*.in.lidar modules; each has errors when I try to build each one separately:
(r.in.lidar)
: /error while loading shared libraries: libproj.so.12: cannot open shared object file: No such file or directory
../../include/Make/Html.make:14: recipe for target 'r.in.lidar.tmp.html' failed
make: *** [r.in.lidar.tmp.html] Error 1
rm r.in.lidar.tmp.html
(r3.in.lidar)
../../include/Make/Html.make:14: recipe for target 'r3.in.lidar.tmp.html' failed
make: *** [r3.in.lidar.tmp.html] Error 1
rm r3.in.lidar.tmp.html
(v.out.lidar)
: error while loading shared libraries: libproj.so.12: cannot open shared object file: No such file or directory
../../include/Make/Html.make:14: recipe for target 'v.out.lidar.tmp.html' failed
make: *** [v.out.lidar.tmp.html] Error 1
rm v.out.lidar.tmp.html
(v.in.lidar)
:: error while loading shared libraries: libproj.so.12: cannot open shared object file: No such file or directory
../../include/Make/Html.make:14: recipe for target 'v.in.lidar.tmp.html' failed
make: *** [v.in.lidar.tmp.html] Error 1
rm v.in.lidar.tmp.html
Your suggestions on resolving these issues will be appreciated.
TIA,
Rich
On Tue, 6 Mar 2018, Rich Shepard wrote:
(r.in.lidar) : /error while loading shared libraries: libproj.so.12:
I see that someone added a couple of .html files to the trunck branch in
release 72331. Unfortunately, these did not fis the problems. Here're the
error messages and the results of running 'make' in each directory:
Errors in:
/home/rshepard/gis/grass/grass7_trunk/raster/r.in.lidar
/home/rshepard/gis/grass/grass7_trunk/raster3d/r3.in.lidar
/home/rshepard/gis/grass/grass7_trunk/vector/v.out.lidar
/home/rshepard/gis/grass/grass7_trunk/vector/v.in.lidar
~/gis/grass/grass7_trunk/raster/r.in.lidar]$ make
if [ "/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/r.in.lidar" != "" ] ; then GISRC=/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/demolocation/.grassrc75 GISBASE=/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu PATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/scripts:$PATH" PYTHONPATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/etc/python:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/scripts:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/lib:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/lib:/usr/lib/qt
/lib:" LC_ALL=C LANG=C LANGUAGE=C /home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/r.in.lidar --html-description < /dev/null | grep -v '</body>\|</html>' > r.in.lidar.tmp.html ; fi
/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/r.in.lidar: error while loading shared libraries: libproj.so.12: cannot open shared object file: No such file or directory
~/gis/grass/grass7_trunk/raster3d/r3.in.lidar]$ make
if [ "/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/r3.in.lidar" != "" ] ; then GISRC=/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/demolocation/.grassrc75 GISBASE=/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu PATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/scripts:$PATH" PYTHONPATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/etc/python:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/scripts:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/lib:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/lib:/usr/lib/q
t/lib:" LC_ALL=C LANG=C LANGUAGE=C /home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/r3.in.lidar --html-description < /dev/null | grep -v '</body>\|</html>' > r3.in.lidar.tmp.html ; fi
/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/r3.in.lidar: error while loading shared libraries: libproj.so.12: cannot open shared object file: No such file or directory
~/gis/grass/grass7_trunk/vector/v.out.lidar]$ make
if [ "/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/v.out.lidar" != "" ] ; then GISRC=/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/demolocation/.grassrc75 GISBASE=/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu PATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/scripts:$PATH" PYTHONPATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/etc/python:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/scripts:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/lib:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/lib:/usr/lib/q
t/lib:" LC_ALL=C LANG=C LANGUAGE=C /home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/v.out.lidar --html-description < /dev/null | grep -v '</body>\|</html>' > v.out.lidar.tmp.html ; fi
/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/v.out.lidar: error while loading shared libraries: libproj.so.12: cannot open shared object file: No such file or directory
~/gis/grass/grass7_trunk/vector/v.in.lidar]$ make
if [ "/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/v.in.lidar" != "" ] ; then GISRC=/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/demolocation/.grassrc75 GISBASE=/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu PATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/scripts:$PATH" PYTHONPATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/etc/python:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/scripts:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/lib:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/lib:/usr/lib/qt
/lib:" LC_ALL=C LANG=C LANGUAGE=C /home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/v.in.lidar --html-description < /dev/null | grep -v '</body>\|</html>' > v.in.lidar.tmp.html ; fi
/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/v.in.lidar: error while loading shared libraries: libproj.so.12: cannot open shared object file: No such file or directory
Perhaps later today or tomorrow?
TIA,
Rich
Rich,
To me that looks like library not in LD_LIBRARY_PATH error or library version changed after compilation of GRASS.
Markus,
The latter is probably the reason. Installed here are:
/usr/lib/libproj.so.13
/usr/lib/libproj.so.13.0.0
/usr/lib/libproj.so
But, I cannot compile the latest GRASS release (72331) because of the
missing .html files.
I suppose I can cd to those directories and touch the filenames so I can
build GRASS against the upgraded libproj.so.
Rich
No, this won't work. The error message is the lack of a makefile 'all' for
r.in.lidar.tmp.html (and the other three modules), but that file does not
exist in the source tree:
~/gis/grass/grass7_trunk/raster/r.in.lidar]$ ls
filters.c r.in.lidar.html r_in_lidar_zrange.svg
filters.h r_in_lidar.png rast_segment.c
info.c r_in_lidar_base_raster.png rast_segment.h
local_proto.h r_in_lidar_base_raster.svg string_list.c
main.c r_in_lidar_binning_count.png support.c
point_binning.c r_in_lidar_binning_mean.png test/
point_binning.h r_in_lidar_dem_mean3D.jpg testsuite/
The file, r.in.lidar.html exists, but not r.in.lidar.tmp.html. Is the tmp
file generated during the build process? If so, I wonder why the Makefile
doesn't include it.
Rich
2018-03-07 20:17 GMT+01:00 Rich Shepard <rshepard@appl-ecosys.com>:
probably liblas is compiled against different version of libproj. Try
to recompile liblas first.
Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Wed, 7 Mar 2018, Martin Landa wrote:
probably liblas is compiled against different version of libproj. Try to
Martin,
Installed here are libproj-4.4.7 and proj-5.0.0. Today I rebuilt
libLAS-1.8.1 and libspatialite (gdal rebuilt yesterday) so the latest qgis
would build.
Rich
On Tue, Mar 6, 2018 at 5:22 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
attention as I’m not currently using lidar data.
(r.in.lidar)
Apparently your liblas installation does not find libproj.so.12.
If you compiled liblas from source, please recompile liblas.
If you installed liblas from your distro’s repo, this distro’s repo is broken and you need to compile liblas from source.
HTH,
Markus M
Markus,
There are two issues and I think they're becoming conflated.
Issue 1: I cannot invoke the installed grass-7.5 because it was built
against libproj.so.12.0.0 and that library has been upgraded to
libproj.so.13.0.0. This issue will be resolved by building the new svn
source against the newer libproj library.
Issue 2: Building the new version fails because of errors in:
and when I run make in each of those directories it fails because it cannot
find the *.tmp.html files.
I can re-post those attempts at running 'make' in each *.lidar directory
if desired.
HTH,
Rich
On Wed, Mar 7, 2018 at 10:27 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
Markus,
There are two issues and I think they’re becoming conflated.
libproj.so.13.0.0.
that means you need to rebuild liblas and maybe its dependencies, before you recompile GRASS
Markus M
I can re-post those attempts at running ‘make’ in each *.lidar directory
if desired.
HTH,
Rich
grass-user mailing list
grass-user@lists.osgeo.org
you recompile GRASS
Markus,
Thank you. The errors I reported were not being able to compile lidar html
files which seemed to me to be independent of the spatial libraries.
Taking your advice, I recompiled and re-installed proj, gdal, geos,
libLAS, laszip, blas/lapack (and OpenBLAS but the system cannot find it),
etc. Surprisingly (to me) this did the trick.
While I don't understand the relationship of these libraries to the build
error I accept that there is such a relationship.
Best regards,
Rich
