My colleague and me are a little confused about an error message of
r.in.mat on his installations of Grass (first 6.2.3, then 6.3RC5. SuSE
Linux 10.2 on Xeon quadcore, uname -a states Linux colleaguespc
2.6.18.2-34-default #1 SMP Mon Nov 27 11:46:27 UTC 2006 x86_64 x86_64
x86_64 GNU/Linux)
Trying to import a mat4-file generated with octave on my machine
(same GRASS versions, first SuSE 10.0 then 10.2, P4_3 dual core, uname
-a states Linux mypc 2.6.18.2-34-default #1 SMP Mon Nov 27 11:46:27 UTC
2006 i686 i686 i386 GNU/Linux),
r.in.mat aborts on my colleague's machine with the message it was only
prepared for importing little endian files.
On my machine I could import the mat fles with any of the above
mentioned combinations of Linux and Grass version. Octave is version
2.1.73 on my machine.
Has something like this happened to you? Do I have to set additional
flags in Octave maybe?
Thanks and Cheers
Bernhard
Dipl.-Ing.
Bernhard Dobmeier
Bayerisches Zentrum für Angewandte Energieforschung e.V.
ZAE Bayern
Abteilung 1 : Technik für Energiesysteme und Erneuerbare Energien
x86_64 GNU/Linux)
I think it is the 64 bit version of "long" creating the problem.
____________________________________________________________________________________
You rock. That's why Blockbuster's offering you one month of Blockbuster
Total Access, No Cost. http://tc.deals.yahoo.com/tc/blockbuster/text5.com
You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost. http://tc.deals.yahoo.com/tc/blockbuster/text5.com
thanks for your reply and sorry for the double post
To avoid source code modifications, our workaround was to set up a
common mapset on a server. Christian (who you identified as my
colleague) can now access the maps I imported from mat4 files without
any problems.
Bernhard
Am Freitag, den 04.04.2008, 02:33 -0700 schrieb Hamish:
> x86_64 GNU/Linux)
Dipl.-Ing.
Bernhard Dobmeier
ZAE Bayern
