[GRASS-user] r.mapcalc appears to have changed behavior
Jim, et al.,
I am not an authority on GRASS, but it may not have been you that 'did
that' - if you were using an earlier version and did a significant
upgrade or a fresh install of a newer version of GRASS, some fine
details like this might end up with new default values (?) I recall
doing a few re-installs/upgrades and having to keep a close eye on user
settings, mapset locations, etc when starting up a newer GRASS.
May not be what happened in your case, but worth keeping in mind if/when
you are moving around GRASS versions or using it on other computers etc,
check up on some of the environment variables as you go. Help docs have
info on how to find the gory detail :slight_smile:
Subject: Re: [GRASS-user] r.mapcalc appears to have changed behavior
To: Michael Barton <michael.barton@asu.edu>
Cc: grass-user grass-user <grass-user@lists.osgeo.org>
Message-ID:
        <CAE=Y9-Tfacpyg_cSaP9w_5U47MdCu_PHuxmaywURw2kEvz0HTw@mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
Thank you. !
I am not sure how I did that but I am sure it seemed like a good idea at
the
time :slight_smile:
Jim
Fortunately, upgrading GRASS should have no effect on the region settings for maps.
Michael
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Sep 30, 2011, at 11:35 PM, Shane Litherland wrote:
Jim, et al.,
Message-ID:
Thank you. !
the
time :slight_smile:
Jim
Nice to know I can remove one possibility from my list of computing
worries :slight_smile:
regards,
shane.
Michael
C. Michael Barton
> Jim, et al.,
> From: Jim Mochel <jim.mochel.hivol@gmail.com>
> Message-ID:
> Thank you. !
> the
> time :slight_smile:
> Jim
