[GRASS-user] r.stream.order problem making on mac os x
I put the r.stream.order sources into my raster folder in the grass
sources. I tried both the from Jarek's website and the svn
grass-addons both threw this error message. The old version compiled
and worked fine on my mac 10.5.7. Any help would be greatly
appreciated.
Stephen Sefick
test -d OBJ.i386-apple-darwin9.8.0 || mkdir -p OBJ.i386-apple-darwin9.8.0
gcc -I/Users/sefick/Grass_Source/grass-6.4.0RC5/dist.i386-apple-darwin9.8.0/include
-g -O2 -DPACKAGE=\""grassmods"\"
-o OBJ.i386-apple-darwin9.8.0/io.o -c io.c
io.c:1:27: error: grass/glocale.h: No such file or directory
In file included from io.c:2:
global.h:5:23: error: grass/gis.h: No such file or directory
global.h:66: error: syntax error before ‘*’ token
global.h:67: error: syntax error before ‘*’ token
global.h:78: error: syntax error before ‘*’ token
global.h:78: warning: data definition has no type or storage class
global.h:79: error: syntax error before ‘*’ token
global.h:79: warning: data definition has no type or storage class
io.c: In function ‘open_raster’:
io.c:9: error: storage size of ‘cellhd’ isn’t known
io.c:11: warning: assignment makes pointer from integer without a cast
io.c:17: error: ‘CELL_TYPE’ undeclared (first use in this function)
io.c:17: error: (Each undeclared identifier is reported only once
io.c:17: error: for each function it appears in.)
io.c:27: error: invalid use of undefined type ‘struct Cell_head’
io.c: In function ‘create_base_maps’:
io.c:38: error: ‘CELL’ undeclared (first use in this function)
io.c:38: error: ‘r_dirs’ undeclared (first use in this function)
io.c:38: error: ‘r_streams’ undeclared (first use in this function)
io.c:39: error: ‘DCELL’ undeclared (first use in this function)
io.c:39: error: ‘r_accum’ undeclared (first use in this function)
io.c:47: error: syntax error before ‘)’ token
io.c:48: error: syntax error before ‘)’ token
io.c:50: error: syntax error before ‘)’ token
io.c:52: error: syntax error before ‘)’ token
io.c:53: error: syntax error before ‘)’ token
io.c:55: error: syntax error before ‘)’ token
io.c:62: warning: assignment makes pointer from integer without a cast
io.c:63: warning: assignment makes pointer from integer without a cast
io.c:73: error: syntax error before ‘)’ token
io.c: In function ‘stream_number’:
io.c:120: error: ‘CELL’ undeclared (first use in this function)
io.c:120: error: syntax error before ‘c_min’
io.c:123: warning: assignment makes pointer from integer without a cast
io.c:125: error: ‘c_min’ undeclared (first use in this function)
io.c:125: error: ‘c_max’ undeclared (first use in this function)
io.c: In function ‘write_maps’:
io.c:132: error: ‘CELL’ undeclared (first use in this function)
io.c:132: error: ‘strahler_buf’ undeclared (first use in this function)
io.c:132: error: ‘shreeve_buf’ undeclared (first use in this function)
io.c:132: error: ‘hack_buf’ undeclared (first use in this function)
io.c:132: error: ‘horton_buf’ undeclared (first use in this function)
io.c:134: error: storage size of ‘history’ isn’t known
io.c:138: error: ‘CELL_TYPE’ undeclared (first use in this function)
make: *** [OBJ.i386-apple-darwin9.8.0/io.o] Error 1
Stephen Sefick
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods. We are mammals, and have not exhausted the
annoying little problems of being mammals.
                -K. Mullis
They have compiled after a
make clean
make
make install
but I am getting a bus error
appreciated.
Stephen Sefick
Stephen Sefick
                                                           \-K\. Mullis
Stephen Sefick
                -K. Mullis
OK,
I got a clean source 6.4RC05 directory and copied the r.stream.*
modules into the raster folder in the sources.
I issued this from CL:
./configure --with-freetype
--with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2
/Library/Frameworks/FreeType.framework/unix/include"
--with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib
--with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config
--with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include
--with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib
--with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj
--with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
--with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
--with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
--without-postgres --without-mysql --with-odbc --with-sqlite
--with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib
--with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include
--with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include
--with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib
--with-cxx --with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers
/Library/Frameworks/Tk.framework/Headers
/Library/Frameworks/Tk.framework/PrivateHeaders"
--with-tcltk-libs=/usr/local/lib --with-x --without-motif
--without-glw --with-python
--with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.10.1/bin/wx-config
--with-opengl=aqua --without-readline --prefix=/Applications
--enable-macosx-app
make
sudo make install
I am building a MacOSX .app and this works just fine. I can use GRASS
and everything that I have tried has worked fine. The
r.stream.extract function worked wonderfully and output raster maps
from r.terraflow flow accumulation and direction map. I tried to feed
this into r.stream.order. I got a bus error on the command line, and
in the GUI it just stops. In both instances I get a ignore report mac
GUI message. This is what I did with the previous ordering software -
r.stream, and everything worked fine. If there is anymore information
that I can provide please tell me and I will be happy to provide this.
Thanks for all of the help
Stephen Sefick
make clean
make
make install
appreciated.
Stephen Sefick
Stephen Sefick
                                                           \-K\. Mullis
Stephen Sefick
                                                           \-K\. Mullis
Stephen Sefick
                -K. Mullis
There should be a crash log for r.stream.order, which you can find in your home logs with Console.app. The trace is especialy useful, though the binary images info can be helpful.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
Is this what you were talking about? If it is not I can find it if
you tell me what I am looking for.
Process: r.stream.order [73041]
Path: /Applications/GRASS-6.4.app/Contents/MacOS/bin/r.stream.order
Identifier: r.stream.order
2 r.stream.order 0x0000213e write_maps + 46
3 r.stream.order 0x00002b71 main + 897
4 r.stream.order 0x00001a56 start + 54
    0x1000 - 0x3fff +r.stream.order ??? (???)
<7ba7322bd390054caeff9595a09fd4d0>
On Sun, Sep 27, 2009 at 4:37 PM, William Kyngesburye
Stephen Sefick
                -K. Mullis
Is that all the binary images lines? If so, then somehow compilation didn't link the GRASS libraries.
There are no changes listed in grass-addons SVN after it was added, so I can't tell if something changed in the Makefile since it last worked for you.
All generalizations are dangerous, even this one.
I found this:
Process: r.stream.order [74338]
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: bash [74313]
Date/Time: 2009-09-27 17:25:16.172 -0500
OS Version: Mac OS X 10.5.8 (9L31a)
Report Version: 6
Anonymous UUID: AA611A0B-FCCB-4FAB-8FCC-6E661CB57A3F
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000001
Crashed Thread: 0
Thread 0 Crashed:
0 libgrass_gis.dylib 0x00080877
G__name_is_fully_qualified + 23 (nme_in_mps.c:66)
1 libgrass_gis.dylib 0x000822bc G__open_raster_new + 60
(opencell.c:640)
Thread 0 crashed with X86 Thread State (32-bit):
  eax: 0xbfffc100 ebx: 0x0008228d ecx: 0x00082b55 edx: 0xbfffc200
  edi: 0x00000001 esi: 0xbfffc100 ebp: 0xbfffc0c8 esp: 0xbfffc0bc
   ss: 0x0000001f efl: 0x00010292 eip: 0x00080877 cs: 0x00000017
   ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
  cr2: 0x00000001
Binary Images:
    0xb000 - 0xffff +libgrass_datetime.dylib ??? (???)
<5db41a672f765dfa7bcb6b3069beba0a>
/Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_datetime.dylib
   0x64000 - 0xa0fe7 +libgrass_gis.dylib ??? (???)
<bf887db89bcb7094a6af0e2b0d157a0b>
/Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_gis.dylib
0x8fe00000 - 0x8fe2db43 dyld 97.1 (???)
<458eed38a009e5658a79579e7bc26603> /usr/lib/dyld
0x9053a000 - 0x90548ffd libz.1.dylib ??? (???)
<5ddd8539ae2ebfd8e7cc1c57525385c7> /usr/lib/libz.1.dylib
0x9137c000 - 0x914e3ff3 libSystem.B.dylib ??? (???)
<ae47ca9b1686b065f8ac4d2de09cc432> /usr/lib/libSystem.B.dylib
0x96b0b000 - 0x96b12fe9 libgcc_s.1.dylib ??? (???)
<f53c808e87d1184c0f9df63aef53ce0b> /usr/lib/libgcc_s.1.dylib
0x97361000 - 0x97365fff libmathCommon.A.dylib ??? (???)
/usr/lib/system/libmathCommon.A.dylib
0xffff0000 - 0xffff1780 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
On Sun, Sep 27, 2009 at 5:43 PM, William Kyngesburye
you.
Path:
your
Stephen Sefick
                -K. Mullis
well, r.stream.order is completely rewritten. Coud you tell me more about your bus error?
stephen sefick pisze:
OK,
--enable-macosx-app
make
sudo make install
Stephen Sefick
make clean
make
make install
appreciated.
Stephen Sefick
Stephen Sefick
                                                               -K. Mullis
Stephen Sefick
                                                               -K. Mullis
Hi
I identified the error, it will be fixed in next few hours
Jarek
fixed in svn
William Kyngesburye pisze:
