[GRASS-user] r.stream.slope
Justing wondering has anyone used r.stream.slope module?
If so, what is it actually calculating?
Thanks to all who has helped me throughout the year! I’ve only recently started using Grass gis and find it absolutely brilliant!
Nollaig Shona daoibh - happy Christmas in Irish!!
Le gach dea ghui,
Shane Carey
GIS and Data Solutions Consultant
It calculates for each individual stream reach the difference in elevation, the average slope, and as a bonus you can get the minimum and maximum curvature (change in slope). Cheers
On 2017-12-25 00:18 AM, Shane Carey wrote:
Le gach dea ghui,
Shane Carey
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
+972-523-665918
Shane Carey wrote
Thanks to all who has helped me throughout the year! I've only recently
Le gach dea ghui,
*Shane Carey*
*GIS and Data Solutions Consultant*
grass-user@.osgeo
https://grass.osgeo.org/grass72/manuals/addons/r.stream.slope.html
Which information is missing in the manual?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
The input has to be the flow direction raster that is created by r.watershed.
From the manpage (as Helmut suggested):
*direction*
Flow direction: name of input direction map produced by *r.watershed* or *r.stream.extract*. If r.stream.extract output map is used, it only has non-NULL values in places where streams occur. NULL (nodata) cells are ignored, zero and negative values are valid direction data if they vary from -8 to 8 (CCW from East in steps of 45 degrees). Direction map shall be of type CELL values. Region resolution and map resolution must be the same.
It's best to keep these questions on the maillist.
On 2017-12-25 14:44 PM, Shane Carey wrote:
Sorry to bothering you again Micha, just one last question! When I run it, I get back raster dcell maps for gradient for the entire area and not just the streams. I presume I have to use the river network I previously created to extract the values at the streams.
Thanks
On Mon, Dec 25, 2017 at 10:39 AM, Shane Carey <careyshan@gmail.com> wrote:
Thanks, you’re a star Micha!
Thanks
Le gach dea ghui,
Shane Carey
Micha Silver
Ben Gurion Univ.
+972-523-665918
Le gach dea ghui,
Shane Carey
Le gach dea ghui,
Shane Carey
Micha Silver
Ben Gurion Univ.
+972-523-665918
