[GRASS-user] r.sun - beam irradiance issues in mountain area with a high relief energy
hi,
given a a mountain area with a high relief energy based upon an ALS DEM with a 1x1m resolution
and system: winGRASS GIS 8.2.1
g.region -p
projection: 99 (MGI / Austria Lambert)
zone: 0
datum: hermannskogel
ellipsoid: bessel
north: 358599.5
south: 345055.5
west: 221323.5
east: 236275.5
nsres: 1
ewres: 1
rows: 13544
cols: 14952
cells: 202509888
DEM range of data: min = 1197.4 max = 3496.68
the horizon rasters are calculated by
r.horizon elevation=als@data step=30 maxdistance=5000 output=horangle
r.sun is calculated for 15 June
r.sun elevation=als@data aspect=als_aspect@data slope=als_slope@data horizon_basename=horangle horizon_step=30 beam_rad=beam_rad166 day=166 nprocs=2 npartitions=2
see the result screenshot in https://pasteboard.co/YShtdFG8C7jk.png
o the high peak has northern, eastern and southern oriented steep slopes
o the more red, the higher beam irradiance calculated by the r.sun command above
o the southern oriented footslopes show a high beam irradiance (as exptected)
o the southern oriented and very steep slopes around the peak show a similar low beam irradiance as the northern slopes (not expected)
I have issues to interpret the results, especially the last pattern:
o Could be the lower beam irradiance in the very southern oriented slopes nearby the peak due to the very steep slope?
o Do slopes with a high inclination (though southern oriented) reduce beam irradiance in the implemented model?
Kind regards
Helmut
This could be potentially a problem described in https://github.com/OSGeo/grass/pull/2534.
Could you try to run this with the changes in the PR?
Anna
On Tue, Jan 31, 2023 at 4:05 PM Helmut Kudrnovsky <hellik@web.de> wrote:
hi,
g.region -p
zone: 0
ellipsoid: bessel
north: 358599.5
south: 345055.5
west: 221323.5
east: 236275.5
nsres: 1
ewres: 1
rows: 13544
cols: 14952
cells: 202509888
Kind regards
Helmut
grass-user mailing list
grass-user@lists.osgeo.org
Hi Anna,
yes, it seems to be similar.
no chance to test the PR at the moment.
Best
Helmut
Hi Anna,
I hopefully correctly applied this PR now here locally in my winGRASS. :wink:
DEM: Airborne Laser Scan 1 x 1 m
projection: 99 (MGI / Austria GK West)
zone: 0
ellipsoid: bessel
north: 218281.5
south: 204874.5
west: 49389.5
east: 62610.5
nsres: 1
ewres: 1
rows: 13407
cols: 13221
cells: 177253947
*patched r.sun*
r.sun elevation=laser_dgm@data aspect=laser_dgm_aspect@data slope=laser_dgm_slope@data horizon_basename=horangle horizon_step=30 beam_rad=beam_rad_166 day=166
Number of threads <1>
Mode 2: integrated daily irradiation for a given day of the year
Using Linke constant: 3.000000
Using albedo constant: 0.200000
Using slope map <laser_dgm_slope@data>
Using aspect map <laser_dgm_aspect@data>
*elevation - computional region
https://pasteboard.co/g82fQtvdcbeE.png
*aspect - computional region
https://pasteboard.co/jV36f8fb1xoY.png
*beam irr 166 - computional region
https://pasteboard.co/no7YUTqNtEPg.jpg
*aspect zoom to the high altitudinal south oriented mountain face with a high slope gradient and high local geomorphological variability
https://pasteboard.co/u10fbgnUU4nX.png
*slope zoomed to the high altitudinal south oriented mountain face with a high slope gradient and high local geomorphological variability
https://pasteboard.co/5FeilT6qRj7t.png
*slope zoomed only 50-90 degrees on the high altitudinal south oriented mountain face with a high slope gradient and high local geomorphological variability
https://pasteboard.co/ssmNEUWyagYe.png
*beam irr 166 zoom on the high altitudinal south oriented mountain face with a high slope gradient and high local geomorphological variability
https://pasteboard.co/PVSjFWy2qcOK.png
later on I'll post a screenshot of the not patched r.sun in 8.2.1
best
helli
