[GRASS-user] r.sun with shadowing effects
I need to calculate the solar radiation (with r.sun) of a relatively small area taking into account the shadowing effect of reliefs spread in a much larger area. In order to be able to get a high resolution map of the area of interest, or even just the values relatives to some particular sites, is there a way to avoid the long computational time needed for areas I’m not interested in?
May be I can use r.los for selecting the reliefs that actually cast a shadow on the area of interest?
Thanks in advance for your answer.
Odoardo Zecca
Dott. Odoardo Zecca
Institut Agricole Régional
Regione La Rochère 1/A
11100 Aosta
email: o.zecca@iaraosta.it
Tel. +39 0165 215884
Fax +39 0165 215800
there a way to avoid the long computational time needed for areas I'm not
interested in?
I don't think so (at least not without modifying the code), but I would be
interested in the same functionality.
That would be ok for the beam radiation, but you might affect the diffuse and
reflective radiation calculations that way. ?
Hamish
____________________________________________________________________________________
Need a vacation? Get great deals
to amazing places on Yahoo! Travel.
http://travel.yahoo.com/
small
of
interested in?
There is some hope: from JRC I received an unpublished r.sun2 + r.horizon
which separates (the slow) horizont calculation from the (much faster)
energy
calculations. Run r.horizon once and then r.sun2 as often as you need.
I'll check if I can put it into GRASS Addons SVN.
View this message in context: http://www.nabble.com/r.sun-with-shadowing-effects-tf4569151.html#a13103922
Thank you, Hamish and Markus.
I look forward downloading the new r.sun2 and r.horizon!
Odoardo
   Odoardo
The new r.sun2 and r.horizon are now available in the
GRASS SVN Addons repository. The documentation still needs
to be updated (see TODO file therein).
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
