[GRASS-user] r.watershed G_malloc error
Hi All,
I’m on windows xp using GRASS 6.4 and 7 and I’m getting the following error running r.watershed:
ERROR: G_malloc: unable to allocate 2521456396 bytes of memory at init_vars.c:137
I’ve 2Gb of ram and the dtm I’m using is 185Mb in (pre import) ascii grid format, so not massive. Is the above error because I’m short on ram for the above process, or is it something else?
Michael
On Wed, Apr 13, 2011 at 3:37 PM, Michael Spencer
<michael_spencer@live.co.uk> wrote:
Hi All,
I'm on windows xp using GRASS 6.4 and 7 and I'm getting the following error
init_vars.c:137
I've 2Gb of ram and the dtm I'm using is 185Mb in (pre import) ascii grid
format, so not massive. Is the above error because I'm short on ram for the
1. make sure the current region settings are ok, i.e. not extending
beyond the extents of the dtm and aligned to the dtm (g.region
align=dtm)
2. use the disk swap mode with r.watershed -m
Markus M
Thanks Mark, and others.
I found a pc with a bit more ram, reduced the region to the dtm and it was fine.
Michael
Date: Wed, 13 Apr 2011 16:12:22 +0200
Subject: Re: [GRASS-user] r.watershed G_malloc error
To: michael_spencer@live.co.uk
CC: grass-user@lists.osgeo.org
michael_spencer@live.co.uk wrote:
Hi All,
init_vars.c:137
    align=dtm)
Markus M
