[GRASS-user] rainfall data
which command do I use to model rainfall data in GRASS6?
Kind Regards
TS Gumede
Candidate Researcher
Meraka Institute, CSIR
office : 012 841 2606
mobile : 072 258 1650
You are going to have to be more specific. Are you trying to
interpolate a rainfall map from several pluviometric stations or do
you have precipitation maps from some other source and want to open
them in Grass?
To interpolate the rainfall check out the v.surf.* modules
Daniel
Kind Regards
TS Gumede
grass-user mailing list
grass-user@lists.osgeo.org
You then need to import the data in Grass. After you created the
correct location and mapset you can use r.in.gdal to import the data.
If your .tiff image has projection information you can use it to
create the location
Daniel
On Wed, May 5, 2010 at 9:10 AM, Sandile Gumede <akasandile@gmail.com> wrote:
Hi
I've got TRMM "rainfall" data (in .tiff format), I want to do analysis on
the data and estimate how much rainfall has fallen to the surface, check if
there is possibility for flooding to occur. Which commands to pass to
perform this?
On Wed, May 5, 2010 at 1:49 PM, Daniel Victoria <daniel.victoria@gmail.com>
them in Grass?
Daniel
> Kind Regards
> TS Gumede
Kind Regards
TS Gumede
There are several option. See here for GRASS related publications:
http://www.citeulike.org/user/neteler/article/4509581
http://www.citeulike.org/user/neteler/article/4078343
2010/5/5 Markus Neteler <neteler@osgeo.org>:
Thanks, the publications were great!
In the same context, I would like to ask for very simple tips about
how to import several rainfall gauge stations.
For instance, a csv or txt file with the following columns "gauge
station name", owner, North, East, "annual rainfall, Elevation, "max
24 hrs".
I have failed from the db.connection or db.in.org (if that is the
begining) and the availa
Then, it would be nice to link a data serie (date, rain) with its gauge station.
Any tips to make it easer will be very welcome,
Marco
