[GRASS-user] raster boxplots wrong assignment
Dear community
I tested the r.boxplot addon and it is definitively possible to run the addon with more than 20 classes/regions/sites/squares.
Furthermore I realised the reason for the wrong assignment of class to raster, but I am not yet able to fix it.
  • The challenge is, that (at the moment) I have raster data for one class (one square), but in total I have 150 squares. So at the moment it just selects the first square (either by cat oder ID_Quadrat).
  • It seems however, if I have raster data for all squares, r.boxplot is working fine.
  • My question: Is it possible to assign raster data for one individual class/squares, of you have missing data for other classes/squares?
Kind regards
Sibylle
First using this code here:
v.to.rast input=Untersuchungsquadrate_2020_2024@PERMANENT output=Quadrate use=attr attribute_column=“ID_Quadrat” label_column=“ID_Quadrat”
r.boxplot -o input=U803174_abgeschnitten zones=Quadrate bx_sort=ascending raster_statistics=median
Second using this code here:
v.to.rast input=Untersuchungsquadrate_2020_2024@PERMANENT output=Quadrate use=attr attribute_column=cat label_column=“ID_Quadrat”
From: sibylle.stoeckli@gmx.ch sibylle.stoeckli@gmx.ch
Sent: Thursday, May 30, 2024 9:27 AM
To: ‘grass-user@lists.osgeo.org’ grass-user@lists.osgeo.org
Subject: RE: raster boxplots wrong assignment
Dear community
I am still wondering, if the r.boxplot addon is working with just a limited number of areass/sites/regions?
Kind regards
Sibylle
From: sibylle.stoeckli@gmx.ch <sibylle.stoeckli@gmx.ch>
Sent: Saturday, May 25, 2024 3:48 PM
To: ‘grass-user@lists.osgeo.org’ <grass-user@lists.osgeo.org>
Subject: raster boxplots wrong assignment
Dear community
I would like to plot boxplots from a raster _pres_apple_spring_merged for different 1 km2 squares (38 squares, Fig. 1, layer “Untersuchungsquadrate”). I was using the same code as used before for 12 regions:
https://ecodiv.earth/post/drawing-boxplots-of-raster-values/ (Author Paulo van Breugel). All layers have the same projection (EPSG:2056, CH1903+/LV95). However, when loading the layer squares (Untersuchungsquadrate) GRASS GIS was asking for reprojection.
  • I got now a warning message, that I have a lot of categories, however, the modelling time was fast (Fig 2)
  • The error is now, that the boxplot is not showing all squares (e.g. ID_Quadrat 803174) and the boxplots are assigned to the wrong square (ID_Quadrat) (Fig. 3)
Kind regards
Sibylle Stöckli
Fig. 1
Fig. 2
Figure 3
Hi Sibylle:
I’m not sure I fully understand the problem. If the below example is not relevant, just ignore…
I did a simple test using the nc_spm_08 location. The PERMANENT mapset includes an elevation raster ‘elev_srtm_30m’ and a categorical landcover raster ‘landclass96’. I used the landcover raster as zones, and elevation for the values in the boxplots.
g.region -ap rast=elev_srtm_30m
All landcover zones
r.boxplot input=elev_srtm_30m zones=landclass96 raster_statistics=median output=~/work/tmp/boxplot.png --o
See attached boxplot image
Now limit to only one zone, the forests, class 5 in this raster:
r.mapcalc “MASK = if(landclass96 == 5, 1, null())”
r.boxplot input=elev_srtm_30m zones=landclass96 raster_statistics=median output=~/work/tmp/boxplot_forest.png
See attached boxplot_forest
r.mask -r
Hope this is somehow helpful.
(attachments)
On 31/05/2024 10:35, sibylle via grass-user wrote:
Dear community
Kind regards
Sibylle
To:grass-user@lists.osgeo.orggrass-user@lists.osgeo.org
Dear community
Kind regards
Sibylle
To:grass-user@lists.osgeo.org’ <grass-user@lists.osgeo.org>
Dear community
Kind regards
Sibylle Stöckli
Fig. 1
Fig. 2
Figure 3
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
Dear Micha
Thanks a lot interesting idea: Unfortunately I got a parse error. However the error/challenge is bevore selecting a specific region or site. I was able to plot one boxplot using a different code.
The challenge is that I use this code here to make “Quadrate/Squares” out of the vector layer “Untersuchungsquadrate”, because in r.boxplot you have input raster and zonal raster. Exactly in this code you make the assignment by defining attribute_column. I used both cat and ID_Quadrate, but it seems that my rasterized file “Quadrate” is not yet the one I need.
Ecodiv.earth - Boxplots based on raster data in GRASS GIS
Sent: Friday, May 31, 2024 11:09 AM
To: sibylle.stoeckli@gmx.ch; grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] raster boxplots wrong assignment
Hi Sibylle:
All landcover zones
r.mask -r
Dear community
  1. The challenge is, that (at the moment) I have raster data for one class (one square), but in total I have 150 squares. So at the moment it just selects the first square (either by cat oder ID_Quadrat).
  2. It seems however, if I have raster data for all squares, r.boxplot is working fine.
  3. My question: Is it possible to assign raster data for one individual class/squares, of you have missing data for other classes/squares?
Kind regards
Sibylle
Dear community
Kind regards
Sibylle
Dear community
  1. I got now a warning message, that I have a lot of categories, however, the modelling time was fast (Fig 2)
  2. The error is now, that the boxplot is not showing all squares (e.g. ID_Quadrat 803174) and the boxplots are assigned to the wrong square (ID_Quadrat) (Fig. 3)
Kind regards
Sibylle Stöckli
Fig. 1
Fig. 2
Figure 3
Micha Silver
Ben Gurion Univ.
(attachments)
On 31/05/2024 12:48, sibylle.stoeckli@gmx.ch wrote:
Dear Micha
Can you post the output of: v.info -c Untersuchungsquadrate_2020_2024 ? (Just to verify the ID_Quadrate column)
OK, after this command you should have a new raster “Quadrate” with pixel values taken from the cat values of the vector. (Why cat and not the ID_Quadrate?)
In the r.mapcalc expression:
1- The full expression needs to be in double quotes,
2- You need to use an existing raster map. Not the vector attribute values.
i.e.
r.mapcalc “MASK = if(Quadrate == 803174), 1, NULL())”
But, as you can see below (since you used the Untersuchungsquadrate_2020_2024 cat values (instead of the ID_Quadrate attrib), the raster values vary from 1 to 179. No value 803174…
I’d suggest to go back to using ID_Quadrate as attribute_column in your v.to.rast . Then try the r.mapcalc expression to get the mask defined. (Don’t forget to remove the mask after: r.mask -r)
HTH
Hi Sibylle:
All landcover zones
r.mask -r
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle Stöckli
Fig. 1
Fig. 2
Figure 3
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Yes: see line 3
Sent: Friday, May 31, 2024 12:06 PM
Dear Micha
i.e.
HTH
Hi Sibylle:
All landcover zones
r.mask -r
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle Stöckli
Fig. 1
Fig. 2
Figure 3
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Dear Micha
Dear community
Find enclosed the two files necessary to run the code:
  • The raster file to plot boxplots: al_pres_apple_spring_merged.tif
  • The vector/shape file for the different quares (classes, regions…):Untersuchungsquadrate_2020-2024_shp
https://drive.google.com/drive/folders/14UwptmBQTtKYQFGeecRWa0n_lWDhRc9s?usp=sharing
Code based on
g.region -a vector=Untersuchungsquadrate_2020_2024
raster= al_pres_apple_spring_merged.tif
r.mask vector=Untersuchungsquadrate_2020_2024
à Here is the identified challenge: transformation form “Untersuchungsquadrate” to “Quadrate” (as input for r.boxplot). attribute_column ID_Quadrat or cat provide false assignment. It just takes Number 1 (either cat or ID_Quadrat.
r.boxplot -o input=al_pres_apple_spring_merged.tif zones=Quadrate bx_sort=ascending raster_statistics=median
Kind regards
Sibylle
Sent: Friday, May 31, 2024 12:10 PM
To: ‘Micha Silver’ tsvibar@gmail.com; ‘grass-user@lists.osgeo.org’ grass-user@lists.osgeo.org
Subject: RE: [GRASS-user] raster boxplots wrong assignment
Yes: see line 3
Dear Micha
i.e.
HTH
Hi Sibylle:
All landcover zones
r.mask -r
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle Stöckli
Fig. 1
Fig. 2
Figure 3
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Hi Sibylle:
So the problem is getting all the vector quadrats as a single value into the “zones” raster? Then I would use the parameters:
‘attr=val value=1’ in the v.to.rast step.
Here, below, are the steps I tried. At the start I would point out that the raster “al_pres_apple_spring_merged.tif” has very low variance, with almost all cells at value 0. When you make of boxplot of these values, you get a very narrow band near to the median value, very near to zero. Maybe that’s what is causing the confusion.
Create new GRASS location/mapset based on geotiff
grass -c al_pres_apple_spring_merged.tif ./CH1903+LV95
Now in that location Import both layers
$ r.import input=al_pres_apple_spring_merged.tif output=al_pres
$ g.region -ap rast=al_pres
projection: 99 (CH1903+ / LV95)
zone: 0
datum: ch1903
ellipsoid: bessel
north: 1270975
south: 1118025
west: 2527000
east: 2804000
nsres: 25
ewres: 25
rows: 6118
cols: 11080
cells: 67787440
Create raster for zones, all quadrats with the same value
$ v.to.rast input=quadrat output=quadrat use=val value=1
Prepare boxplot, I add the ‘-o’ flag to also plot outliers
$ r.boxplot -o input=al_pres zones=quadrat output=“al_pres_boxplot.png” raster_statistics=median
Have a look at the attached plot.
Now I check the univariate statistics of the al_pres raster:
al_pres univariate statistics
$ r.univar al_pres
100%
total null and non-null cells: 67787440
total null cells: 0
Of the non-null cells:
(attachments)
On 03/06/2024 13:55, sibylle.stoeckli@gmx.ch wrote:
Dear Micha
Dear community
Code based on
Kind regards
Sibylle
To: ‘Micha Silver’ tsvibar@gmail.com; ‘grass-user@lists.osgeo.orggrass-user@lists.osgeo.org
Yes: see line 3
Dear Micha
i.e.
HTH
Hi Sibylle:
All landcover zones
r.mask -r
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle Stöckli
Fig. 1
Fig. 2
Figure 3
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Dear Micha
Ah I see your suggestion for
# Create raster for zones, all quadrats with the same value
  • Is it possible to plot several squares/classes with v.to.rast? So something similar to Fig 1 (all squaraes) or just the squares with values in the raster file “al_pres_apple_spring_merged.tif”?
  • To challenge with fig 1 is that the assignment of “ID_Quadrat” to the values in the raster file “al_pres_apple_spring_merged.tif” is wrong. Instead of “value 1” I would like the assignment to “ID_Quadrat” similar to fig 1. For example I do not have values for the last one, “737182”. The order is somehow mixed-up.
Kind regards
Sibylle
Fig 1
Sent: Monday, June 3, 2024 3:11 PM
To: sibylle.stoeckli@gmx.ch; grass-user@lists.osgeo.org; p.vanbreugel@gmail.com
Hi Sibylle:
zone: 0
datum: ch1903
ellipsoid: bessel
north: 1270975
south: 1118025
west: 2527000
east: 2804000
nsres: 25
ewres: 25
rows: 6118
cols: 11080
cells: 67787440
$ r.univar al_pres
100%
total null cells: 0
n: 67787440
minimum: 0
maximum: 0.315331
range: 0.315331
mean: 3.23424e-05
mean of absolute values: 3.23424e-05
standard deviation: 0.0022431
variance: 5.03148e-06
variation coefficient: 6935.47 %
sum: 2192.40546066407
Note that the variance is quite small. No wonder that the boxplot shows the median as a very narrow band almost at value zero.
Again, if I’m missing something, let me know.
Dear Micha
Dear community
  1. The raster file to plot boxplots: al_pres_apple_spring_merged.tif
  2. The vector/shape file for the different quares (classes, regions…):Untersuchungsquadrate_2020-2024_shp
Code based on
Kind regards
Sibylle
Yes: see line 3
Dear Micha
i.e.
HTH
Hi Sibylle:
All landcover zones
r.mask -r
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle Stöckli
Fig. 1
Fig. 2
Figure 3
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Hi Sibylle:
(attachments)
On 04/06/2024 10:07, sibylle.stoeckli@gmx.ch wrote:
Dear Micha
Yes, sure. But does it make sense to produce 179 (the number of quadrats) separate boxplots?
Here’s an example where I choose only the ID_Quadrat between 730000 and 740000 (11 quadrats). Then I converted to raster and did a boxplot.
Note that only one quadrat, 734128, has any pixels with “al_pres_apple_spring” values above 0.
$ v.extract quadrat out=quadrat_hi where=“ID_Quadrat>730000 and ID_Quadrat<740000” --o
$ v.to.rast quadrat_hi out=quadrat_hi use=attr attribute_column=ID_Quadrat
$ r.boxplot -o input=al_pres zones=quadrat_hi output=“al_pres_boxplot_hi.png” raster_statistics=median --o
This quadrat does appear in the attached plot. But with a thin line at the median, since all pixels in that quadrat have al_pres_apple_spring values of zero. In fact I notice that all pixels throughout the al_pres_apple_spring are zero, except for a few of the quadrats. It looks as if this al_pres_apple_spring was either masked, or prepared in advance to cover only certain quadrats. Does that make sense? Do you have the original al_pres_apple_spring map?
Kind regards
Sibylle
Fig 1
Hi Sibylle:
zone: 0
datum: ch1903
ellipsoid: bessel
north: 1270975
south: 1118025
west: 2527000
east: 2804000
nsres: 25
ewres: 25
rows: 6118
cols: 11080
cells: 67787440
$ r.univar al_pres
100%
total null cells: 0
n: 67787440
minimum: 0
maximum: 0.315331
range: 0.315331
mean: 3.23424e-05
Dear Micha
Dear community
Code based on
Kind regards
Sibylle
Yes: see line 3
Dear Micha
i.e.
HTH
Hi Sibylle:
All landcover zones
r.mask -r
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle Stöckli
Fig. 1
Fig. 2
Figure 3
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Dear Micha
Thank you very much. Perfect I was able to reproduce your code with v.extract.
Yes it makes sense. The values in the raster file are the output of a pollination model. Before investing a lot of time and to compare the output of different land-use maps and climate scenarios I decided to work on a subsample, e.g. 15 squares (or classes). At the end I will have around 50 squares and present just these squares.
One last question
It is really strange, but when selecting ID_Quadrat between 52000 and 6000 (boxplot values for 3 squares are available, not just for one square) the assignment is still wrong
v.extract Untersuchungsquadrate_2020_2024 out=quadrat_hi where=“ID_Quadrat>52000 and ID_Quadrat<600000”
The boxplot should be for 527120, 569118 and 581166, and not for 503150, 563190, 575110 (figure see attachment).
Kind regards
Sibylle
Sent: Tuesday, June 4, 2024 1:21 PM
Hi Sibylle:
Dear Micha
  1. Is it possible to plot several squares/classes with v.to.rast? So something similar to Fig 1 (all squaraes) or just the squares with values in the raster file “al_pres_apple_spring_merged.tif”?
  1. To challenge with fig 1 is that the assignment of “ID_Quadrat” to the values in the raster file “al_pres_apple_spring_merged.tif” is wrong. Instead of “value 1” I would like the assignment to “ID_Quadrat” similar to fig 1. For example I do not have values for the last one, “737182”. The order is somehow mixed-up.
Kind regards
Sibylle
Fig 1
Hi Sibylle:
zone: 0
datum: ch1903
ellipsoid: bessel
north: 1270975
south: 1118025
west: 2527000
east: 2804000
nsres: 25
ewres: 25
rows: 6118
cols: 11080
cells: 67787440
$ r.univar al_pres
100%
total null cells: 0
n: 67787440
minimum: 0
maximum: 0.315331
range: 0.315331
mean: 3.23424e-05
Dear Micha
Dear community
Code based on
Kind regards
Sibylle
Yes: see line 3
Dear Micha
i.e.
HTH
Hi Sibylle:
All landcover zones
r.mask -r
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle Stöckli
Fig. 1
Fig. 2
Figure 3
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
(attachments)
(attachments)
On 05/06/2024 11:33, sibylle.stoeckli@gmx.ch wrote:
Dear Micha
One last question
52000 or 520000 ??
Kind regards
Sibylle
Hi Sibylle:
Dear Micha
Kind regards
Sibylle
Fig 1
Hi Sibylle:
zone: 0
datum: ch1903
ellipsoid: bessel
north: 1270975
south: 1118025
west: 2527000
east: 2804000
nsres: 25
ewres: 25
rows: 6118
cols: 11080
cells: 67787440
$ r.univar al_pres
100%
total null cells: 0
n: 67787440
minimum: 0
maximum: 0.315331
range: 0.315331
mean: 3.23424e-05
Dear Micha
Dear community
Code based on
Kind regards
Sibylle
Yes: see line 3
Dear Micha
i.e.
HTH
Hi Sibylle:
All landcover zones
r.mask -r
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle Stöckli
Fig. 1
Fig. 2
Figure 3
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Remote Sensing Lab, Sde Boker
Ben Gurion University
+972-523-665918
Dear Micha
Many many thanks for your valuable GRASS GIS support.
It would be very interesting to see your output using v.extract with three boxplots
v.extract Untersuchungsquadrate_2020_2024 out=quadrat_hi where=“ID_Quadrat>520000 and ID_Quadrat<600000”
Kind regards
Sibylle
Sent: Wednesday, June 5, 2024 2:53 PM
Dear Micha
Hmm it doesn’t make any difference. Strange.
Thanks a lot
Sibylle
Sent: Wednesday, June 5, 2024 1:19 PM
Dear Micha
One last question
52000 or 520000 ??
Kind regards
Sibylle
Hi Sibylle:
Dear Micha
Kind regards
Sibylle
Fig 1
Hi Sibylle:
zone: 0
datum: ch1903
ellipsoid: bessel
north: 1270975
south: 1118025
west: 2527000
east: 2804000
nsres: 25
ewres: 25
rows: 6118
cols: 11080
cells: 67787440
$ r.univar al_pres
100%
total null cells: 0
n: 67787440
minimum: 0
maximum: 0.315331
range: 0.315331
mean: 3.23424e-05
Dear Micha
Dear community
Code based on
Kind regards
Sibylle
Yes: see line 3
Dear Micha
i.e.
HTH
Hi Sibylle:
All landcover zones
r.mask -r
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle Stöckli
Fig. 1
Fig. 2
Figure 3
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
+972-523-665918
Here it is:
$ v.extract quadrat out=quadrat_3 where=“ID_Quadrat>520000 and ID_Quadrat<600000” --o
$ v.to.rast quadrat_3 out=quadrat_3 use=attr attribute_column=ID_Quadrat --o
$ r.boxplot -o input=al_pres zones=quadrat_3 output=“al_pres_boxplot_3.png” raster_statistics=median --o
HTH
(attachments)
On 07/06/2024 16:56, sibylle.stoeckli@gmx.ch wrote:
Dear Micha
Kind regards
Sibylle
Dear Micha
Thanks a lot
Sibylle
Dear Micha
One last question
52000 or 520000 ??
Kind regards
Sibylle
Hi Sibylle:
Dear Micha
Kind regards
Sibylle
Fig 1
Hi Sibylle:
zone: 0
datum: ch1903
ellipsoid: bessel
north: 1270975
south: 1118025
west: 2527000
east: 2804000
nsres: 25
ewres: 25
rows: 6118
cols: 11080
cells: 67787440
$ r.univar al_pres
100%
total null cells: 0
n: 67787440
minimum: 0
maximum: 0.315331
range: 0.315331
mean: 3.23424e-05
Dear Micha
Dear community
Code based on
Kind regards
Sibylle
Yes: see line 3
Dear Micha
i.e.
HTH
Hi Sibylle:
All landcover zones
r.mask -r
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle Stöckli
Fig. 1
Fig. 2
Figure 3
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
+972-523-665918
Micha Silver
Ben Gurion Univ.
Dear Micha
That’s really strange, using the same code, I got another boxplot with the wrong assignment.
Did you re-order or postprocess “Untersuchungsquadrate_2020-2024”?
New mask before v.extract? For example 511150 is >52000 but does not appear in your boxplot. However, the assignment in your boxplot is perfect.
v.extract Untersuchungsquadrate_2020_2024 out=quadrat_3 where=“ID_Quadrat>520000 and ID_Quadrat<600000” --o
r.boxplot -o input=al_pres_apple_spring_merged zones=quadrat_3 output=“al_pres_boxplot_3.png” raster_statistics=median –o
Kind regards
Sibylle
Sent: Saturday, June 8, 2024 11:50 AM
Here it is:
HTH
Dear Micha
Kind regards
Sibylle
Dear Micha
Thanks a lot
Sibylle
Dear Micha
One last question
52000 or 520000 ??
Kind regards
Sibylle
Hi Sibylle:
Dear Micha
Kind regards
Sibylle
Fig 1
Hi Sibylle:
zone: 0
datum: ch1903
ellipsoid: bessel
north: 1270975
south: 1118025
west: 2527000
east: 2804000
nsres: 25
ewres: 25
rows: 6118
cols: 11080
cells: 67787440
$ r.univar al_pres
100%
total null cells: 0
n: 67787440
minimum: 0
maximum: 0.315331
range: 0.315331
mean: 3.23424e-05
Dear Micha
Dear community
Code based on
Kind regards
Sibylle
Yes: see line 3
Dear Micha
i.e.
HTH
Hi Sibylle:
All landcover zones
r.mask -r
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle Stöckli
Fig. 1
Fig. 2
Figure 3
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
+972-523-665918
Micha Silver
Ben Gurion Univ.
(attachments)
Dear Micha
I am still wondering, why the square 521150 is not part of your boxplot when selecting squares between 520000 to 600000?
I still get the wrong assignment using the same code, however, my boxplot shows all squares > 520000
The difference is that I use v.extract Untersuchungsquadrate and your code is v.extract quadrate.
How do you define “quadrate” is there an additional command line?
Here my code
Set the region and MASK ALL-EMA
g.region -a vector=Untersuchungsquadrate_2020_2024 raster=al_pres_apple_spring_merged
Kind regards
Sibylle
Here it is:
HTH
Dear Micha
Kind regards
Sibylle
Dear Micha
Thanks a lot
Sibylle
Dear Micha
One last question
52000 or 520000 ??
Kind regards
Sibylle
Hi Sibylle:
Dear Micha
Kind regards
Sibylle
Fig 1
Hi Sibylle:
zone: 0
datum: ch1903
ellipsoid: bessel
north: 1270975
south: 1118025
west: 2527000
east: 2804000
nsres: 25
ewres: 25
rows: 6118
cols: 11080
cells: 67787440
$ r.univar al_pres
100%
total null cells: 0
n: 67787440
minimum: 0
maximum: 0.315331
range: 0.315331
mean: 3.23424e-05
Dear Micha
Dear community
Code based on
Kind regards
Sibylle
Yes: see line 3
Dear Micha
i.e.
HTH
Hi Sibylle:
All landcover zones
r.mask -r
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle Stöckli
Fig. 1
Fig. 2
Figure 3
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
+972-523-665918
Micha Silver
Ben Gurion Univ.
Hi Sibylle:
It took me a few minutes to understand. I see that the quadrat 521150 is outside of the region of al_pres_apple_spring_merged.tif.
You can see here:
r.import input=al_pres_apple_spring_merged.tif output=al_pres --o
v.import input=untersuchungsquadrate_2020_2024.gpkg output=quadrat --o
v.info -g quadrat
The west extent of the al_pres is west=2502999.442. But the quadrat with ID 521150 is further west, outside of the raster.
So the v.to.rast command (which honors the region setting) skips that quadrat. Does that make it clearer?
Regards, Micha
(attachments)
On 25/06/2024 16:30, sibylle.stoeckli@gmx.ch wrote:
Dear Micha
Here my code
Kind regards
Sibylle
Here it is:
HTH
Dear Micha
Kind regards
Sibylle
Dear Micha
Thanks a lot
Sibylle
Dear Micha
One last question
52000 or 520000 ??
Kind regards
Sibylle
Hi Sibylle:
Dear Micha
Kind regards
Sibylle
Fig 1
Hi Sibylle:
zone: 0
datum: ch1903
ellipsoid: bessel
north: 1270975
south: 1118025
west: 2527000
east: 2804000
nsres: 25
ewres: 25
rows: 6118
cols: 11080
cells: 67787440
$ r.univar al_pres
100%
total null cells: 0
n: 67787440
minimum: 0
maximum: 0.315331
range: 0.315331
mean: 3.23424e-05
Dear Micha
Dear community
Code based on
Kind regards
Sibylle
Yes: see line 3
Dear Micha
i.e.
HTH
Hi Sibylle:
All landcover zones
r.mask -r
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle
Dear community
Kind regards
Sibylle Stöckli
Fig. 1
Fig. 2
Figure 3
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
+972-523-665918
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
