[GRASS-user] raster data output
Hello list -
There may be a simple solution to my problem, but I'm a bit new to
grass and haven't been able to track it down yet, so I was wondering
if anyone had suggestions. I'm trying to output the cell contents of
multiple rasters into a single table that I can save to a file with
the desired result looking like this:
x-coord y-coord raster1 raster2 raster3 ...
    0 0 1 2 3 ...
    0 1 0 1 2 ...
    0 2 0 0 1 ...
etc...
with the idea of doing some time series analyses, where the subsequent
rasters are different time steps. Ideally this would come out as one
table that I could then import into R for analysis. I've had a bit of
luck outputing the result of r.stats -x to a file using some bash
scripting and then combining all those files manually, but it seems
there would be an easier solution.
Any suggestions would be appreciated.
Thanks!
-Steve
Did you see:
http://grass.fbk.eu/statsgrass/grass_geostats.html
Am 10.11.2010 16:23, schrieb Steve Wangen:
Hello list -
     0 0 1 2 3 ...
     0 1 0 1 2 ...
     0 2 0 0 1 ...
etc...
Thanks!
-Steve
grass-user mailing list
grass-user@lists.osgeo.org
Take a look at r.what manual page. There you can supply a list of
coordinates and the rasters you want to query to get the desired
table.
On Wed, Nov 10, 2010 at 3:03 PM, Achim Kisseler
<ak7@jupiter.uni-freiburg.de> wrote:
Did you see:
Hello list -
0 0 1 2 3 ...
0 1 0 1 2 ...
0 2 0 0 1 ...
etc...
Thanks!
-Steve
