Martina Schaefer wrote:
thanks for your answer to my raster/ascii questions and sorry for the
late replay, I had to move to something else for a moment (deadline for
corrections to a paper) and then I was a bit playing around with the
commands you showed me.
g.region followed by r.stats or r.out.ascii does indeed what I was
looking for, but in my Map Display window is still written the old
resolution and I think the map is also drawn with the old resolution. Is
there a possibility to do these?
The GUI has its own set of region settings, so you need to change the
region from within the GUI to affect how a map is displayed within the
GUI.
Or you can explicitly resample the map with r.resamp, r.resamp.interp,
or r.resamp.stats, then display the resampled map in the GUI.
In fact, the simple resampling with the nearest-neighbour is probably
not good enough, so I was trying r.surf.idw as I can't make your
commands r.resamp work,
Which version of GRASS are you using? r.resamp.interp and
r.resamp.stats aren't present in 6.2.3, only in 6.3.x.
and I would like to visualize my interpolation
without each time exporting to ascii and visualizing with another program!
You can view the resampled maps in the GUI, or with d.rast.
Is there also a possibility to save the data with the new resolution, so
that I don't have to do it each time?
Explicitly resampling the data will create a new map.
And, one last question, I have three sets of raster data of the same
region (ice thickness, bedrock and surface elevation of a glacier). How
can I get them into the same grass LOCATION? I would like to have access
to them at the same time and also make some simple operations like for
example the difference of two of the datasets!
Data is normally imported into the current location, unless you
explicitly import into a new location with e.g. r.in.gdal's location=
option.
If the rasters have different projections, you will need to import
each one into a separate location, then switch to the target location
and re-project the data with r.proj.
