Adam,
If all else fails, work with a command line process ... I've never had happy experiences with the purely GUI rectification.
i.group (groupname) (mapname)
i.target (groupname) Target_Location Target_Mapset
d.mon X0
i.points (groupname) - this launches the GCP capture GUI (old style, X-windows but it works!)
i.rectify (groupname) extension="something" order=(polynomial order)
RC
Message: 1
Date: Mon, 30 Nov 2009 14:38:04 -0700
Subject: Re: [GRASS-user] Georectify problem
To: "grass-user@lists.osgeo.org" <grass-user@lists.osgeo.org>
Message-ID: <6C956E66-153C-4152-809E-B4C28AB7442A@asu.edu>
Content-Type: text/plain; charset=US-ASCII; format=flowed; delsp=yesGiven the platform you are on and the fact that you are using an up-to- date build of GRASS 6.4, I recommend you do this with the new wxPython GUI instead of the TclTk one. I think it will work better for you.
Michael
On Nov 30, 2009, at 2:16 PM, grass-user-request@lists.osgeo.org wrote:
Date: Mon, 30 Nov 2009 09:57:42 -0800
Subject: [GRASS-user] Georectify problem
To: GRASS user list <grass-user@lists.osgeo.org>
Message-ID: <684BACB4-CEAF-4CDD-98D1-9F3EE5742C1C@exponent.com>
Content-Type: text/plain; charset=us-asciiI am trying to georectify an xy image. I think that I am doing things correctly yet I keep getting an error. Perhaps someone can clear things up for me.
I imported the image into an XY location. I then went to the location that I want to import into and brought up a map so I could click on points.
If then select file-> georectify. I fill in the info and then click Start georectifying. It brings up the manage ground control points window and a display showing the xy map to be georectified. If I click there I can add the GCP xy coords. But if I then click in my original window to select the georgraphic coords I get an error: can't read "b1 coords" : no such variable.can't read "b1coords": no such variable
while executing
"$geoentry insert 0 $b1coords"
invoked from within
"if { [info exists geoentry] } {
(command bound to event)I can't figure out why it will not let me select the points. I have selected the arrow tool in the map display.
I am using a Mac with William Kyngesburye's binary builds. I have 6.4 RC5-3 Snow with OS 10.6.2
--Adam
------------------------------Message: 2
Date: Mon, 30 Nov 2009 14:40:45 -0700
Subject: Re: [GRASS-user] Trouble setting location and projection
Message-ID: <01B9BF6F-B613-45FA-8520-38EC61489D50@asu.edu>
Content-Type: text/plain; charset=US-ASCII; format=flowed; delsp=yesOn Nov 30, 2009, at 2:16 PM, grass-user-request@lists.osgeo.org wrote:
Date: Mon, 30 Nov 2009 13:03:16 -0600
Subject: [GRASS-user] Trouble setting location and projection
To: <grass-user@lists.osgeo.org>
Message-ID: <COL121-W561C882825F5984EB916E8B6970@phx.gbl>
Content-Type: text/plain; charset="iso-8859-1"I am trying to set the project location and cordinate system using the 6.4.0svn version for windows but I keep getting the projection error,
'g.proj.exe-p' when I try and start Grass. I have a GIS background and I am frustrated that I can't get it to work. I want to use the projection nad83UTM Zone 14N. I have read through all of the tuturiols and help sheets and looked at the FAQs with no such luck. I really want to use this program to help with my job so if you would help me get started I would greatly appreciate it.
Sincerely,
Ross Benisch
Can you give us some more specific information? Are you using the location wizard? Is this the newest windows binary? Which version of Windows are you using? What exactly is the error message that you get?Michael
Message: 3
Date: Tue, 01 Dec 2009 01:37:43 +0100
To: grass-user@lists.osgeo.org
Message-ID:
<5304763.17158.1259627864390.JavaMail.fmail@fmcert01.dlan.cinetic.de>
Content-Type: text/plain; charset="iso-8859-15"I am trying to set the project location and cordinate system using the 6.4.0svn version for windows but I keep getting the projection error,
'g.proj.exe-p' when I try and start Grass. I have a GIS background and I am frustrated that I can't get it to work. I want to use the projection nad83UTM Zone >14N. I have read through all of the tuturiols and help sheets and looked at the FAQs with no such luck. I really want to use this program to help with my job so >if you would help me get started I would greatly appreciate it.
Sincerely,
Ross Benisch
hi Ross,
please open a bug report at
https://trac.osgeo.org/grass/wiki
by specifying Windows-Installer, steps to reproduce the error, Windows-version etc.
so important information can't get lost in the mailing list
best regards
Helmut
___________________________________________________________________________________
Pop-Diva Sarah Kreuz und ihr beeindruckendes Debütalbum "One Moment in Time". Jetzt reinhören! http://produkte.web.de/go/05/-------------- next part --------------
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20091201/0ed6f741/smime-0001.bin------------------------------
Message: 4
Date: Tue, 01 Dec 2009 01:45:50 +0100
Message-ID:
<9735556.17178.1259628351250.JavaMail.fmail@fmcert01.dlan.cinetic.de>
'g.proj.exe-p' when I try and start Grass. I have a GIS background and I am frustrated that I can't get it to work. I want to use the projection nad83UTM >Zone >14N. I have read through all of the tuturiols and help sheets and looked at the FAQs with no such luck. I really want to use this program to help with >my job so >if you would help me get started I would greatly appreciate it.
Sincerely,
Ross Benisch
hi Ross,
best regards
Helmut
maybe related to following bug report:http://trac.osgeo.org/grass/ticket/827
please add your comments
best regards
Helmut___________________________________________________________________________________
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20091201/c3375ab2/smime-0001.bin------------------------------
Message: 5
Date: Tue, 01 Dec 2009 01:48:12 +0100
Subject: [GRASS-user] i.atcorr with MSS band 5,6,7
Message-ID: <hf1p4d$stq$1@ger.gmane.org>
Content-Type: text/plain; charset=ISO-8859-15Dear Grass users,
how can I add spectral conditions of the bands 5,6,7 of the Landsat MSS
sensor?I have seen that these are defined in:
http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/imagery/i.atcorr/Iwave.cppBut is is unclear to me how they are added.
As far as the manual concerned, the pre-defined spectral conditions are
only available to LS MSS band 1-4:http://grass.itc.it/grass64/manuals/html64_user/i.atcorr.html
31 mss (landsat5) band 1 (0.475-0.640)
32 mss (landsat5) band 2 (0.580-0.750)
33 mss (landsat5) band 3 (0.655-0.855)
34 mss (landsat5) band 4 (0.785-1.100)Thanks in advance for any hints,
Marco------------------------------
Message: 6
Date: Mon, 30 Nov 2009 21:14:48 -0800
Subject: Re: [GRASS-user] i.atcorr with MSS band 5,6,7
To: "Marco Tuckner" <marcotuckner@public-files.de>
Cc: grass-user@lists.osgeo.org
Message-ID:
<65b87b606fc185067cf55224e63558f9.squirrel@calmail.berkeley.edu>
Content-Type: text/plain;charset=utf-8I thought the MSS sensor only had 4 bands, and the TMS sensor sensor 7?
Best, MEH
Dear Grass users,
Marco_______________________________________________
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user------------------------------
Message: 7
Date: Tue, 01 Dec 2009 01:32:53 -0500
Subject: [GRASS-user] reading a column/vector of a raster image
Message-ID: <4B14B895.906@cs.utk.edu>
Content-Type: text/plain; charset=ISO-8859-1; format=flowedHi all
I am dealing with a satellite image which has N bands, each band of size row x col. Is there any way to read one column of a certain band or all the bands of a certain point? I only found G_get_raster_row which works for row.
Peng------------------------------
Message: 8
Date: Tue, 1 Dec 2009 09:53:10 +0300
Subject: [GRASS-user] Execution failed g.proj.exe
To: "'grass-user@lists.osgeo.org'" <grass-user@lists.osgeo.org>
Message-ID: <3A03213F2C680F429897406A814DE6AA082F9DE4C0@icipedudumx1>
Content-Type: text/plain; charset="iso-8859-1"Dear List,
I just installed WinGRASS-6.4.0svn-r39740-2-Setup.exe on Windows XP professional and when starting the system using the spearfish database I get the message Error in command execution: Execution failed g.proj.exe -p .
Any ideas?
Bes regards,
Klaus
Klaus Mithöfer Geographic Information Systems (GIS) Officer icipe - International Centre of Insect Physiology and Ecology P.O. Box 30772 - 00100 Nairobi, Kenya Phone: +254-20-8632000, Extn. 2147
Fax: +254-20-8632001/2 Mobile: +254-724-308404
E-Mail: kmithoefer@icipe.org
web: www.icipe.org----------------------------------------------------------------------------
This position is supported by German development cooperation // Centre for international Migration and Development - http://www.cimonline.de/en/index.aspKlaus.mithoefer@cimonline.de
Message: 9
Date: Tue, 01 Dec 2009 10:56:55 +0100
Message-ID:
<7848421.22602.1259661416896.JavaMail.fmail@fmcert01.dlan.cinetic.de>
Content-Type: text/plain; charset="iso-8859-15"Dear List,
I just installed WinGRASS-6.4.0svn-r39740-2-Setup.exe on Windows XP professional and when starting the system using the >spearfish database I get the message Error in command execution: Execution failed g.proj.exe -p .
Any ideas?
Bes regards,
Klaus
please add your comments to following bug report:http://trac.osgeo.org/grass/ticket/827
by specifying the situation when the error comes up.
best regards
Preisknaller: WEB.DE DSL Flatrate für nur 16,99 Euro/mtl.! http://produkte.web.de/go/02/-------------- next part --------------
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20091201/13673d61/smime.bin------------------------------
http://lists.osgeo.org/mailman/listinfo/grass-userEnd of grass-user Digest, Vol 44, Issue 1
