[GRASS-user] Re: grass-user Digest, Vol 44, Issue 47
On Dec 15, 2009, at 11:21 AM, grass-user-request@lists.osgeo.org wrote:
Date: Tue, 15 Dec 2009 18:20:56 +0000
From: Gilbert Ferrara <gilbertferrara1974@gmail.com>
Subject: [GRASS-user] NVIZ on wxpython 6.4
To: grass-user@lists.osgeo.org
Message-ID:
       <bf5eea780912151020i7201b9fcxe030638aa02c3e38@mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
Greetings you all
I'm new at this mailing list and I have a question related with NVIZ module.
I saw in previous messages that NVIZ is available at WinGRASS using TclTK.
But at LINUX it also requires tcltk, right?
Ok I used the command: nviz elevation vect=roadsmajor points=firestations
This should be: nviz elevation=rastermap vect=roadsmajor points=firestations
elevation is an argument. You need a raster map as in elevation=mymap
Michael
and I get NVIZ window totally jammed. And when I unselected "surface" I got
this error window:
Bad window path name ".help_shell"
bad window path name ".help_shell"
   while executing
"winfo reqwidth $_top"
   (procedure "DynamicHelp::_show_help" line 22)
   invoked from within
"DynamicHelp::_show_help .middle.panelarea.panels.main.midt.b2 317 323"
   ("after" script)
Question: Does any one LINUX User, has the same problem? Or knows how to fix
this?
Thanks
Gilbert
