[GRASS-user] Re: Import Interlis format
Thanks Andreas,
But it just doesn't seem a right approach to me to convert a topological format into a simple feature format to import it to GRASS. I am speaking of some 300.000 polygons of buildings and X00.0000 parcels, which created a lot of topological problems when I imported from shapefiles. That's why I did ask the dataowner for the INTERLIS format.
Isn't there any other solution or exchange format that is topological?
Regards, Patrick
P.S. sorry for the late answer- but I was off for 2 Weeks
On 03/12/2011 12:28 AM, grass-user-request@lists.osgeo.org wrote:
Message: 9
Date: Fri, 11 Mar 2011 21:39:20 +0100
Subject: Re: [GRASS-user] interlis import
To:grass-user@lists.osgeo.org
Message-ID:<4D7A8878.6050306@carto.net>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Hi Patrick,
I wouldn't try to open Interlis files directly in GRASS. You are better
off converting them to an intermediate format or database, e.g.
spatialite, PostgreSQL, GML, etc. and work from there.
If you open the files directly, performance will be bad.
btw: Interlis consists of two files:
1. .ili file (contains the data model: topics, tables, columns, data
types, domain lists, etc.)
2. .itf file (the raw data: geometry and attribute data). - itf means
"interlis transfer format"
You always need both files.
Here are one or two examples:http://gis.hsr.ch/wiki/HowTo_OGR2OGR
Good luck,
Andreas
On 3/11/11 8:00 PM, Patrick S. wrote:
> Dear List,
> does someone have experience in importing the topological format
> INTERLIS to GRASS?
> It seems to need an .ili file, that will define polygons, lines and
> points, but I don't see how to integrate this one in the v.in.ogr
> command.
> I managed to use ogr2ogr and tested conversion to shapefile. This one
> uses the java interpreter ili2c.jar. (see:
> http://www.gdal.org/ogr/drv_ili.html). It will only work if the .ili
> is intergrated as in the command:
> ogr2ogr -f "ESRI Shapefile" shpdir
> /home/order/filename.itf,/home/order/description.ili
> When I import the .itf to GRASS it will only create lines instead of
> areas. Same result for conversion with ogr2ogr mentioned above when
> the .ili is not integrated.
> Any Feedback would be helpful.
> Patrick
> P.S. Testfiles can be foundhttp://www.interlis.ch/
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Hi Patrick,
You are right - there are currently only simple feature/non topological formats available in OGR/QGIS and others. GRASS is an exception and I believe that OGR can read old ArcInfo coverages (also a topological format). I just don't know any solution currently.
The problem with Interlis is the bad performance. Parsing the model and polygonizing each time you open a project will always be slower. That's why I suggested the conversion to a different format. Interlis is designed as an exchange format, not a production database. I don't know any GIS (neither commercial or Open Source) that can read/write/edit directly off of Interlis data. Usually there are only import and exports.
Sorry that I don't have a better answer,
Andreas
On Fri, 25 Mar 2011 09:53:55 +0100, Patrick S. wrote:
Thanks Andreas,
format.
Regards, Patrick
Message: 9
Hi Patrick,
Good luck,
Andreas
> Dear List,
> INTERLIS to GRASS?
> command.
> Patrick
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
