Sorry for the delay No, I was not able to fix the problem with v.patch. Although I tried several different suggestions, none of them worked. It still dropped some of the larger regions that were shared between the maps. My only remaining idea, which I have not tried primarily because of the number of separate vector maps is to run v.patch on all of them, and then add the dropped regions one at a time. This may be completely off base, but I wonder if it might have something to do with bounding boxes surrounding each vector map. The box might cut the dropped region when we run v.patch. Just a thought if anyone else reads this.
I did finish the task, but using a less than optimal work around. I converted each of the vector maps to a raster map, and then I patched them together. As I said, less than optimal, but it got the job done.
Brian
On Jun 9, 2008, at 7:49 PM, Oliver Sonnentag wrote:
Hi Brian, just wondering if you ever figured out why v.patch drops boundary vector regions ....
http://lists.osgeo.org/pipermail/grass-user/2008-March/044155.html
I'm facing exactly the very same problem as described in your post at the moment and I can't figure how to get this vector maps v.patch-ed correctly.
In advance, thanks a lot.
Oliver
