[GRASS-user] Re: r.in.wms bug (rchirgwin@ozemail.com.au)
Some progress on this, but I suspect there's something "under the covers" that somebody needs to know about.
The r.in.wms documentation says:
*r.in.wms* [-*ldockp*] [*output*=/string/] *mapserver*=/string/ [*layers*=/string/[,/string/,...]] [*styles*=/string/[,/string/,...]] [*srs*=/string/] *format*=/string/ [*wmsquery*=/string/] *maxcols*=/integer/ *maxrows*=/integer/ [*tileoptions*=/string/] [*region*=/string/] [*folder*=/string/] [*wgetoptions*=/string/] [*curloptions*=/string/] *method*=/string/ [*v*=/integer/] [--*overwrite*] [--*verbose*] [--*quiet*]
Note that "mapserver" appears before layers. If I use this syntax, I get:
ERROR: Required parameter <layers> not set:
    (Layers to request from map server).
However, if I reverse the order of the mapserver and the layers:
r.in.wms output=Background layers=psma:all mapserver=<URL>
- then things work okay. So is it an error in the documentation, or has a more recent release changed the r.in.wms script?
Richard
get:
The parser doesn't really care about the order*; this lends credence to
the theory that you need to quote your strings from the terminal and
the command gets side-tracked with a &|;= before getting to the end.
In the case where layer= comes first it will truncate the mapserver=
option and it will still fail, but later on in the script.
[*] If your mapserver URL contains an unquoted "=" the parser might
treat that part as an option.
Did this once work for you in an earlier version of GRASS?
Hamish
      ____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
get:
Hamish,
Here’s how things stand now.
Quoting properly fixes the problem on Grass-6.3 under Tiger.
However, on Grass-6.3RC4 on Leopard, with the new r.in.wms and wms.downloads installed, I still get the wms.download error on line 118, that -n is an invalid option…
RC
Here's how things stand now.
glad to hear it.
line 118, that -n is an invalid option...
I still would need to see the module debug output to have any idea
about why that is happening. g.gisenv set="DEBUG=1"
Hamish
Looking for last minute shopping deals?
Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
