I believe you need to set the resolution of the project to 450m before importing. I saw you have "g.region vect=gbknH02@venlo" in your script. If this is this the vector with 1000m resolution that would be the problem.
Using "g.region nsres=450 ewres=450" instead should fix it unless you use a geographical projection.
Jarle J. Pedersen
