Yep, GRASS can do it that way, I suggest you look at GMT (http://gmt.soest.hawaii.edu) for quality map production & cartography...
OGR now supports GMT vector (multiline) output, so it is easy to convert data to GMT format for plotting.
Brent Wood
Brent Wood
DBA/GIS consultant
NIWA, Wellington
New Zealand
Wouter <wouter.buytaert@scarlet.be> 12/17/08 7:23 AM >>>
Answer to my own question:
- have your data in UTM
- make a grid in a latlong location with v.mkgrid
- reproject the grid to your UTM location with v.proj
- visualise the grid over your data of interest
- add labels with the latlong coordinates
cheers
wouter
On Tue, 16 Dec 2008, Wouter wrote:
Date: Tue, 16 Dec 2008 14:46:47 -0300 (CLST)
To: grass-user@lists.osgeo.org
Subject: visualising high latitude regions
Particularly for high latitudes such as Patagonia, a straight grid
gives a lot of distortion.
which is nice if you want to output a shapefile to use as an overlay
with e.g. QGIS, but there is a much much easier way...
use 'd.grid -g size=0:30' or 'd.grid -w size=5' to draw eg 30min or 5deg
lat/lon grid over your current map projection display.
d.grid has a number of nice options.
also in ps.map there is the "geogrid" command which does something similar.
& ps.map
