[GRASS-user] Read/Write numpy array
Hello,
I try to do a mapcalculation with scipy (do to limited functionality of
usual mapcalc functions.
Therefore I want to read a map into numpy-array, do the calculation on it and write it back to a GRASS-map. I tried to follow the instructions in the wiki (http://grass.osgeo.org/wiki/GRASS_and_Python#Interfacing_with_NumPy) but I got stucked when it comes to the writing-process.
Thats my code so far:
    x = garray.array()
    x.read("distance_raster")
    Density = garray.array()
    Density = p * stats.norm.pdf(x,loc=m, scale=s1*K) + (1-p) * stats.norm.pdf(x, loc=m, scale=s2*K)
    Density.write("Density")
The stats.norm.pdf is from the stats-scipy module. I get following error when I try to process the script:
AttributeError: 'numpy.ndarray' object has no attribute
'write'
I don't know excactly what how I have to use the write command. I am working on 6.5 and I read there were some problems with numpy-arrays. Are the solved now?
/johannes
GMX DSL Doppel-Flat ab 19,99 Euro/mtl.! Jetzt mit
gratis Handy-Flat! http://portal.gmx.net/de/go/dsl
    x = garray.array()
'write'
The write() method is part of garray.array, which is a subclass of
numpy.array (specifically, of numpy.memmap).
This line:
creates an instance of garray.array and associates the name "Density"
with it.
This line:
creates a normal numpy.array and associates the name "Density" with
it, replacing the original association. Consequently, Density.write()
fails because Density now refers to a numpy.array and not a
garray.array().
Rather than making the name Density refer to the resulting
numpy.array, you have to assign the resulting numpy.array *into* the
existing garray.array to which the name Density already refers, i.e.:
     Density[...] = p * stats.norm.pdf(x,loc=m, scale=s1*K) + (1-p) * stats.norm.pdf(x, loc=m, scale=s2*K)
Note that the "..." (ellipsis) is literal. The above is equivalent to:
     Density[:,:] = p * stats.norm.pdf(x,loc=m, scale=s1*K) + (1-p) * stats.norm.pdf(x, loc=m, scale=s2*K)
I believe that the issue with grass.script.array requiring the 7.0
version of r.{in,out}.bin has been solved by backporting the changes
into 6.5.
Hello Glynn,
Hello Josef,
Thank you for your answer but I still get an error, although I changed the code
which is now:
    x = garray.array()
the error says:
  File "/Library/Frameworks/Python.framework/Versions/2.6/li
b/python2.6/site-packages/scipy/stats/distributions.py",
line 1104, in pdf
    x = arr((x-loc)*1.0/scale)
TypeError: unsupported operand type(s) for /:
'numpy.ndarray' and 'numpy.ndarray'
Propably it has something to do with the stats-norm function of scipy which is working
with numpy array (maybe not with the garray)..or what does that error mean?
PS: @ You once helped me with this scipy equation I now want to use within a python-GRASS-GIS script.
Transforming a raster-map into an array and apply the scipy-function on it and transform it back to a raster.
Maybe you have some ideas what is the problem...
Am 05.04.2011 um 19:43 schrieb Glynn Clements:
   x = garray.array()
'write'
This line:
with it.
This line:
garray.array().
into 6.5.
grass-user mailing list
grass-user@lists.osgeo.org
which is now:
    x = garray.array()
the error says:
line 1104, in pdf
garray.array is a subclass of numpy.memmap which itself is a subclass
of numpy.ndarray. You should be able to use a garray.array anywhere
you can use a numpy array.
But I don't think that has anything to do with the error message,
which suggests that both arguments are plain numpy arrays.
I can't even import scipy.stats here; possibly because SciPy is out of
date with respect to my Python version. I'll have another look when
I've updated SciPy.
Hello,
Am 06.04.2011 um 17:36 schrieb josef.pktd@gmail.com:
On Wed, Apr 6, 2011 at 10:58 AM, Johannes Radinger <JRadinger@gmx.at> wrote:
Hello Glynn,
Hello Josef,
which is now:
   x = garray.array()
the error says:
line 1104, in pdf
I guess is that one of your variables doesn't have a type that is
numpy compatible (or defines division).
My guess is that the exception shows up too late in the code, I would
think there should be an asarray earlier in the
scipy.stats.distributions code. (If it's not then that might be a
bug.)
you could try np.asarray on all your variables and check which one has
not have been converted yet
O thank you for that, I didn't realize that the variables K and s weren't converted
into a float, they were still a string... so stupid from me that I didn't check that
before, I was only thinking about the input array(x)...It is now working!
anyway just some questions about the handling of NULL values. Like in that example:
   x = garray.array()
The distance_raster contains a lot of NULL-values. It seems that they are somehow transformed
into a real value (I don't now to which one exactly) because after the Scipy-calculation (Density[...] =)
and the rewrite process I a value of 0.00101776158703459 in every cell which was a NULL-cell before.
Two questions:
1) is it possible to exclude NULL values from calculation (to speed up the process)
2) What do I've to set that NULL cells remain NULL cells also after the processing?
/johannes
stats.norm.pdf(np.asarray(x), loc=np.asarray(m), scale=np.asarray(s1*K))
I don't know what methods garray.array() inherits or has, so I don't
know any specific answer.
Josef
   x = garray.array()
'write'
This line:
with it.
This line:
garray.array().
into 6.5.
