Glynn Clements wrote:
I think that this change might be necessary, although I don't know if
the problem which you report is related to it.
--- display/drivers/XDRIVER/Respond.c (revision 39378)
+++ display/drivers/XDRIVER/Respond.c (working copy)
@@ -4,6 +4,7 @@
void XD_Respond(void)
+ XSetWindowBackgroundPixmap(dpy, grwin, bkupmap);
XClearWindow(dpy, grwin);
XSync(dpy, 1);
needs_flush = 0;
Glynn,
I applied your patch and found it does not work for me. As noted
earlier, changing settings in nxclient does work. More information is
available in this post from March last year:
http://article.gmane.org/gmane.comp.gis.grass.user/23219
Craig
On Sun, 18 Oct 2009, Craig Leat wrote:
Craig:
Craig Leat wrote:
I can replicate the strange behaviour with d.mon when I use bitmap
compression in NX. Selecting the option "Use plain X bitmaps" in the
nxclient works for me. I hope it works for you too
After selecting "Use plain X bitmaps" within "Custom Settings" I still see "Blank" XDRIVER Windows for my Raster Images... As before d.rast reaches 100% too fast and Raster Files are NOT "Visible", which I always assumed was due to no image data actually being transfered from the Remote Host???
Current Specifics:
Client [Windows XP SP3]: 3.4.0-5
Server [CentOS 4.8]: (Client: 3.4.0-5, Node: 3.4.0-6, Server: 3.4.0-8)
GRASS [6.2.3]: Built from Source Code
Although I can use 3.X Clients, once the Server has been upgraded to 3.X executing d.rast with the XDRIVER Window will again produce "Blank" Raster Images???
NOTE: Other combinations involving NX 3.X have always produced the same
"Problem", it does NOT appeared to be limited to the above mentioned
specifics...
Lawrence Houston -- (grass@greenfield.dyndns.org)
