[GRASS-user] removing join
Hello,
I have performed a join between a vector map and a postgreSQL table using v.db.join. I would like to remove this join now. I cannot figure out how to do this.
Thank you Jennifer
Hello,
I think you can just drop the additional columns with v.db.dropcol.
Micha Silver
GIS Consultant, Arava Development Co.
[http://www.surfaces.co.il](http://www.surfaces.co.il)
Thank you Micha for the quick response. When I perform this join through the GUI on Windows I get the following error
ERROR: value too long for type character (1)
and all my added fields which are of data type character have a length of 1 instead of the original 255. Any ideas what is going on? I am using postgreSQL 9.1 and GRASS 6.4.2 on Windows.
Thanks Jennifer
On 3/28/2012 12:56 PM, Micha Silver wrote:
On 03/28/2012 08:49 PM, Jennifer Boehnert wrote:
Hello,
Thank you Jennifer
grass-user mailing list
grass-user@lists.osgeo.org
This mail was received via Mail-SeCure System.
Micha Silver
Jennifer Boehnert
GIS Coordinator
National Center of Atmospheric Research
PO Box 3000
Boulder, CO, 80307
Hi Jennifer:
Ahhh, I remember something about a bug in the v.db.join script.
The script first gets a list of columns from the join table, then loops thru that list, creates a new column in the target table, and runs an UPDATE to get all the values from the join table into the target. The trouble comes with columns of type CHARACTER - the script does not check the length of the field, so by default (in Postgresql) it creates a field of length 1.
Here's from the PostgreSQL manual:
The notationsvarchar(n)andchar(n)are aliases forcharacter varying(n)andcharacter(n), respectively.characterwithout length specifier is equivalent tocharacter(1). Ifcharacter varyingis used without length specifier, the type accepts strings of any size. The latter is aPostgreSQLextension.
Since the script uses the column definition "CHARACTER" and not "CHARACTER VARYING" the default length is 1.
Here's a way to work around the problem. Let's Suppose you have a target vector called 'vect', and the join table called 'otable', your text column is 'long_text', and the id columns for the join are 'cat' and 'oid', then
# first drop the wrong (length 1) text column
v.db.dropcol vect col=long_text
# Now recreate that column correctly
v.db.addcol vect col="long_text varchar(255)"
# And finally the update
echo "UPDATE vect SET long_text=(SELECT long_text
     FROM otable
     WHERE otable.oid=vect.cat);" | db.execute database=<your db> driver=pg
That's a one time fix. In order to get this working correctly permanently, changes are required to the v.db.join script. I'll suggest this to the devs.
Micha
Thanks Jennifer
Hello,
Thank you Jennifer
Micha Silver
Micha Silver
Thank you very much for the workaround. I will give that a try.
Jennifer
Hi Jennifer:
field of length 1.
'oid', then
FROM otable
this to the devs.
Micha
Thanks Jennifer
Hello,
Thank you Jennifer
Micha Silver
Jennifer Boehnert
GIS Coordinator
PO Box 3000
Boulder, CO, 80307
I recall a similar problem with MySQL, and that Micha Silver produced a join2 script that did not truncate (maybe it can be found in the mail archives?), - this improved script has, apparently, not made it into the most recent releases. SQLite manages with the current join, at least on my Mac.
Jon
Hi Jennifer:
   FROM otable
Micha
Thanks Jennifer
Hello,
Thank you Jennifer
Micha Silver
Micha Silver
Issue opened on trac:
http://trac.osgeo.org/grass/ticket/1631
I’m looking forward to feedback…
The problem does not occur with sqlite because it’s very lax in data types. Sqlite ignores all the length restrictions to data types, and somehow dynamically allocates as much space is needed for each data field. So a column of type CHARACTER is the same as TEXT and the same as VARCHAR(8), or VARCHAR(255) etc.
Micha
Micha Silver
Well, the join2 solved the data length problem and worked for me while I
was using MySQL, but I currently use SQLite as I find it less cumbersome
to set up and manage.
Regards, Jon
> body p { margin-bottom: 0cm; margin-top: 0pt; } On
03/30/2012 07:34 PM, Jon Eiriksson wrote: I recall
     I'm looking forward to feedback...
     The problem does not occur with sqlite because it's very lax in data
     Micha
following error ERROR: value too long for type character (1)
                   Hi Jennifer: Ahhh, I remember something
about a bug in the v.db.join script. The script first gets a
Here's from the PostgreSQL manual: The
not "CHARACTER VARYING" the default length is 1. Here's a
for the join are 'cat' and 'oid', then # first drop the
wrong (length 1) text column v.db.dropcol vect col=long_text
# Now recreate that column correctly v.db.addcol vect
col="long_text varchar(255)" # And finally the update echo
"UPDATE vect SET long_text=(SELECT long_text FROM otable
driver=pg That's a one time fix. In order to get this
v.db.join script. I'll suggest this to the devs. Regards,
Micha and all my added fields which are
postgreSQL 9.1 and GRASS 6.4.2 on Windows. Thanks Jennifer
                    Hello, I have performed a join between a
this. I think you can just drop
         Thank you Jennifer
_______________________________________________ grass-user
mailing list grass-user@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-user This mail
     -- Micha Silver GIS Consultant, Arava Development Co.
Co. http://www.surfaces.co.il
