Hi All,
This is the projection information of a single Landsat scene in ENVI, GRASS and using gdalwarp. GRASS and gdalwarp gave somewhat similar output but ENVI is totally different. I have been informed that the projected image from ENVI is correct as verified from the earlier work.
Original data (in Sinusoidal Projection)
On Sun, Sep 27, 2015 at 1:48 AM, Markus Neteler <neteler@osgeo.org> wrote:
On Sep 26, 2015 1:00 AM, “Uttam Kumar” <uttamsinha09@gmail.com> wrote:
Thank you all. It worked.
However I noticed that the projected boundary values of N, S, W and E in GRASS are not same as the values obtained from projecting the same image in ENVI image processing software and in gdalwarp.
Projection of the scene in Lambert Azimuthal Equal Area is similar (but not exactly equal) in GRASS and gdal, but in ENVI it is totally different. I just did the comparison to see if things are similar from different softwares in case they have to be ported to other platforms.
Can you print the projection information in both GRASS (g.proj -p or -w) and ENVI? Are they really the same?
