Is it possible to get the EPSG code of the active projection (if it exists)?
thank you
Panos
thank you
Panos
Panagiotis Mavrogiorgos wrote
exists)?
if the location was created by an EPSG code, e.g. in the location wizzard:
g.proj -p
-PROJ_INFO-------------------------------------------------
proj : ll
datum : wgs84
ellps : wgs84
no_defs : defined
towgs84 : 0.000,0.000,0.000
-PROJ_EPSG-------------------------------------------------
epsg : 4326
-PROJ_UNITS------------------------------------------------
unit : degree
units : degrees
meters : 1.0
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Retrieve-projection-s-EPSG-code-tp5248374p5248488.html
On Feb 1, 2016 9:37 PM, “Panagiotis Mavrogiorgos” <pmav99@gmail.com> wrote:
You may try this addon:
https://grass.osgeo.org/grass70/manuals/addons/g.proj.identify.html
On Tue, Feb 2, 2016 at 3:49 PM, Markus Neteler <neteler@osgeo.org> wrote:
On Feb 1, 2016 9:37 PM, "Panagiotis Mavrogiorgos" <pmav99@gmail.com>
wrote:
> Hi,
exists)?You may try this addon:
Thank you, both
