[GRASS-user] rgrass7: writeRAST fails with large rasters
I have a large raster (~2 GB) that I’m trying to export to grass from R (3.4.1) using the rgrass7 (0.1-9) library:
writeRAST(
as(raster(“dinf_slope.tif”),“SpatialGridDataFrame”),
“slope.r”,
flags=c(“overwrite”)
The operation fails and throws the following error:
Error in writeBin(z, con = f, size = sz) :
only 2^31-1 bytes can be written in a single writeBin() call
I get the same error if I attempt to export a SpatialGridDatatFrame object directly, so I don’t believe the problem is with the raster library.
I receive the same error in Ubuntu and Windows 10.
How can I use writeRAST to export large rasters to grass?
Cross posted to stack exchange (https://goo.gl/5bBmV3)
writeRAST(
“slope.r”,
this error comes from the R function writeBin. Maybe it would be safer to use writeGDAL within writeRAST.
Don’t use writeRAST, use writeGDAL instead and then import the output of writeGDAL into GRASS.
Markus M
