[GRASS-user] river profile, how to
Hi All,
I wish to develop a river profile from start point to its last. The GRASS 6.4.1 has a tool profile analysis, which is a bit crude. If I take two points, eg. river head and its last point then it gives a profile, but it is a direct and not along the course of the river. And, if I create a series of point all along the course, then certainly not the best values are there as selection process is very tedious. So, is there a method which would automatically take the raster values of the river course seen as a line and give a simple fine river profile.
Thanks
Ambrish Dhaka
If you have the shapefile for the river (or vector line in GRASS) you can convert it to points by using v.to.points and making the points really close to one another (make dmax small). then use v.what.rast to get the elevation at the points locations.
Hope it helps
On Sun, Apr 17, 2011 at 8:18 AM, ambijat <ambijat@hotmail.com> wrote:
Hi All,
Thanks
Ambrish Dhaka
grass-user mailing list
grass-user@lists.osgeo.org
really close to one another (make dmax small). then use /*v.what.rast*/
Instead of v.what.rast, you can also use v.to.db+r.profile as follows (in GNU/Linux command line):
v.to.points myriver dmax=1 out=myriverpoints
v.to.db -p myriverpoints option=coor layer=2 | awk -F'|' '{print $2","$3}' | tail -n +2 | r.profile elevation out=myprofile.txt
adjust dmax to your needs.
Seems like a nice candidate for a simple Python AddOn script to me... :wink:
Moritz
Hope it helps
<mailto:ambijat@hotmail.com>> wrote:
    Hi All,
    fine river profile.
    Thanks
    Ambrish Dhaka
    grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
Thanks! All,
I developed a rather crude but a solid method. What I did was to actually convert the river raster into vector with r.to.vect.points. This automatically delivered me the altitude values for each point. Rest is then reverse engineering.:slight_smile:
Then I opened the dbf file in openoffice calc and added a distance column. I filled that column with the formula to add cumulative sum of resolution at each row (== to raster resolution). This gave me distance and altitude of each point.
Finally I plotted it nicely in chart of openoffice.
I think it was right approach. Any modifications?
regards,
Ambrish
Moritz
Hope it helps
    Hi All,
    fine river profile.
    Thanks
    Ambrish Dhaka
