I'm using some Ordnance Survey street-level Mastermap data which implements street names, house numbers, etc. as map points linked to a database containing the text to print, its size and its rotation.
Before I start hacking the label paint files myself (the format looks nice and simple), is there a way to set size and rotation information on a per-label basis? I'm aiming for a result that looks something like this (rendered by the Edina Digimap service):
The final map is to be the bottom layer of a stack of moderately complicated information and so I'd like to be able to render it myself in a simplified form rather than just importing tiles from the Ordnance Survey.
On Mon, Feb 13, 2012 at 9:34 PM, Asher Hoskins <asher@piceur.com> wrote:
Hello.
As of now, the "rotation" parameter seems to only support global
rotation.
rotation.
but see also the -a and -c flags, which rotates lines according to their
instantaneous slopes.
(v.label.sa is good for making sure labels do not overlap, but neither
(AFAIU) tries to not overlap the vector map underneath, although that
would be nice to have)
