[GRASS-user] setting monitor device
Dear All,
I just intalled the WinGrass 6.3.0 NATIVE for windows and imported a binary map on a mapset environment.
When I try “d.rast myraster” I get:
PNG: GRASS_TRUECOLOR status: TRUE
PNG: collecting to file: C:/GRASS/database/newLocation/PERMANENT/.tmp/3832.0.ppm,
GRASS_WIDTH=387, GRASS_HEIGHT=484
But no information are showed on “Map Display 1” windows.
Need I redirect the raster output to “Map Display 1” or it is the default ?
Thanks in advance,
miltinho astronauta
brazil
When I try "d.rast myraster" I get:
But no information are showed on "Map Display 1" windows.
Need I redirect the raster output to "Map Display 1" or it is the default ?
You cannot control the GUI from the command prompt.
The GUI isn't the same thing as a "monitor". The native Windows
version doesn't have monitors.
If you run d.* commands manually on Windows, they just generate an
image file.
