Hello List,
why are there no input boxes for snap threshold and min_area in the v.in.ogr menu in GRASS 7.0.3? I think those values are important to control the process. On the command line, the values can be entered.
Greets, Uwe
Hello List,
Greets, Uwe
On 09/06/16 10:47, Uwe Fischer wrote:
Hello List,
This is an old discussion. See [1] for example.
The menu entry File->Import vector data->Common import formats actually does not launch v.in.ogr as such, but a GUI import wizard which launches v.in.ogr.
The general gist of those in favor of simple versions of the wizard is that the wizard should only show the basic functionality to ease use.
Those who want to use the full-power v.in.ogr can launch it using v.in.ogr --ui in the console.
In GRASS7.2 the main import wizard actually uses v.import which allows reprojection during the import. It also gives access to the more detailed parameters. However, v.import does not provde min_area. If this is considered necessary, then a ticket should be opened.
Moritz
Moritz,
thank you very much for your help. I understand so far whats going on. But I did not choose any menu items; I typed v.in.ogr in the console window, and then the reduced wizard showed up. So the flag --ui is what I need.
Is --ui available for every GRASS command? Or is there a way for the user to see/to learn if 2 wizards for the same command are existing?
In most cases, I'd love to see all options available because my input datasets often require filtering, selecting or setting tolerances.
Thank you once more.
Mit freundlichen Grüßen,
UWE FISCHER
Von: Moritz Lennert [mailto:mlennert@club.worldonline.be]
Gesendet: Donnerstag, 9. Juni 2016 11:27
An: Uwe Fischer <gisfisch@t-online.de>; grass-user@lists.osgeo.org
Betreff: Re: [GRASS-user] setting snap an min_area for v.in.ogr
Hello List,
Moritz
On 09/06/16 12:55, Uwe Fischer wrote:
Moritz,
Yes. You can see it if you la
Not really, AFAIK. --ui _always_ brings up the actual module GUI. Normally, launching a module with just its name does the same, but for the import and export modules special treatments have been decided within the wxGUI. If you launch the same module in a terminal, you get the original (--ui) GUI.
I personally find this confusing and would have prefered a separate "Import wizard" entry in the GUI menu (with possible g.gui.vimport/rimport modules), but others have the feeling that this makes life easier for newcomers...
+1.
You will always get all options using --ui.
Moritz
