[GRASS-user] Shell scripts to define GISDATABASE, location, and mapset; import data
I write shell scripts to run modules for analyses, but have always used the
GUI to define locations and/or mapsets before importing data even with starting
grass with the -c option.
What I want to do now when importing project data is to have a script that
defines the location and mapset then imports the data.
I've read the startup program manual page
<https://grass.osgeo.org/grass82/manuals/grass.html&gt; several times today
without seeing how to specify the all three parameters to define a location
and mapset and immediately follow that with a data import command; is --exec
really necessary?
An example file is attached. Please correct my format and I'll use this as a
template for all data imports.
TIA,
Rich
(attachments)
quarry-property.sh (365 Bytes)
Hi Rich:
really necessary?
Here's your script with corrections
#!/usr/bin/bash
# set grass location for quarry boundary map
grass -c $HOME/projects/oregon/northside-rock/data/data/property/Tax_Lots.shp /data1/grassdata/quarry-name/permitted-boundary
# Import quarry boundary map
# Comments:
# The 'output' parameter should be just a grass vector name, NOT a path.
# Best to use underscore in map names, NOT '-'
# And '--overwrite' == '--o'
v.import input=$HOME/projects/oregon/northside-rock/data/property/Tax_Lots.shp output=permitted_boundary --overwrite
One additional point that might make this easier: GRASS locations are typically defined by a coordinate reference system. If you work with data in only a few CRS, then you can consider to create a collections of locations, one for each CRS that you use. Then when you start a new project, open grass in the location that contains data in the CRS of the project, and create a new *mapset* just for that project. Then import into that mapset. This approach has two advantages: (1) - You don't need to be creating new locations all the time with possibly redundant CRS definitions. And (2) - you most likely have some data that can be shared between projects. With one overall location defined by i.e. "NAD83(HARN) Oregon", then you can store in the PERMANENT mapset any dataset that might be shared among projects. And each mapset will be specific to one project.
Creating a new project specific mapset, within an existing location is done by:
# Start GRASS in existing location
grass /data/grassdata/some_location/PERMANENT
# create new mapset
g.mapset -c <new_project_name>
# Now import whatever data you need
v.import input=...
Best, Micha
TIA,
Rich
grass-user mailing list
grass-user@lists.osgeo.org
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
Micha,
Thanks very much. You've reminded me of what I've forgotten and taught me
things I didn't know. I'll now be quickly back up to speed with grass.
Best regards,
Rich
