[GRASS-user] simple way to get Easting and Northing coordinates of stream outlet directly from r.watershed?
I'm using GRASS 7.0.3 (text) on Ubuntu Linux, and running it either from a bash shell script or from an R file.
I've worked out a workflow that does what I want, but it is very long and convoluted, so I'm wondering if there is a simple way to extract the Easting and Northing coordinates of the lowest point on the stream network, such that I can then use them as inputs for r.water.outlet?
Here is my workflow, realise it is long
1. run r.watershed to get drainage, streams, and basin
2. run r.stream.order to calculate strahler order and get strahler
    raster map
3. use r.stats and some bash code to extract highest strahler number
    from the strahler map
4. use r.mapcalc .... not sure why, inherited this bit from someone!
5. use r.stats to get data from stream dem into a text file
6. use some bash and awk code to extract the Easting and Northing
    values of the lowest point in the text file created from the stream dem
7. use r.water.outlet to create new drainage map for the basin
8. use r.lfp to calculate longest flow path, also uses the Northing
    and Easting values of the outflow point
So I guess what I'm looking for is a simpler way to get the Northing and Easting values of the lowest point, directly from r.watershed or something analogous.
All suggestions most welcome. Thanks
J
Dr. Jim Maas
University of East Anglia
Did you consider using:
https://grass.osgeo.org/grass70/manuals/addons/r.stream.basins.html
Stefan
-----Original Message-----
From: grass-user [mailto:grass-user-bounces@lists.osgeo.org] On Behalf Of Jim Maas
Sent: 26. april 2016 14:28
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] simple way to get Easting and Northing coordinates of stream outlet directly from r.watershed?
1. run r.watershed to get drainage, streams, and basin 2. run r.stream.order to calculate strahler order and get strahler
    raster map
5. use r.stats to get data from stream dem into a text file 6. use some bash and awk code to extract the Easting and Northing
    values of the lowest point in the text file created from the stream dem 7. use r.water.outlet to create new drainage map for the basin 8. use r.lfp to calculate longest flow path, also uses the Northing
J
Dr. Jim Maas
grass-user mailing list
    raster map
dem
have a look at
https://grasswiki.osgeo.org/wiki/R.basin#Preparation_for_multiple_basins.27_analysis
maybe for some inspirations.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/simple-way-to-get-Easting-and-Northing-coordinates-of-stream-outlet-directly-from-r-watershed-tp5262970p5262976.html
Hi Stefan,
Thanks for this. I've had a look but not tried it yet. Just for me to clarify, are you suggesting that:
1. r.stream.basins will somehow produce and output the Easting and
    Northing values of the overall outlet?
2. r.stream.basins, will replace most of this workflow and thus the
    Eastings and Northings will not be required explicitly?
In the case of 1, I can't quite see how it will output these values?
Thanks a bunch,
J
On 26/04/16 14:02, Blumentrath, Stefan wrote:
Stefan
     raster map
J
Dr. Jim Maas
Dr. Jim Maas
Hi Jim,
I've used r.stream.extract a fair amount. It produces a downstream-oriented vector. In layer 2 of the output stream vector map the "cat" value of 2 indicates outlet points. See (https://grass.osgeo.org/grass64/manuals/addons/r.stream.extract.html) (note this is GRASS 6.4.4 but should be similar for 7.x)
Chris Bartolomei P.E.
Engineer/Scientist
ENSCO, Inc.
4849 North Wickham Road
Melbourne, FL 32940 (official office)
5038 Park Rim Drive
San Diego, CA 92117 (home office)
(858) 581-3005
bartolomei.chris@ensco.com
________________________________________
From: grass-user [grass-user-bounces@lists.osgeo.org] On Behalf Of Jim Maas [j.maas@uea.ac.uk]
Sent: Tuesday, April 26, 2016 6:43 AM
To: Blumentrath, Stefan; grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] simple way to get Easting and Northing coordinates of stream outlet directly from r.watershed?
Hi Stefan,
Thanks a bunch,
J
https://urldefense.proofpoint.com/v2/url?u=https-3A__grass.osgeo.org_grass70_manuals_addons_r.stream.basins.html&d=CwIGaQ&c=DsZY2bea7iNIzyp-7sZ0t0F2UfNQZUfZhEPCv_2wBI0&r=O31ltou6ygJL2Y01kQyNJJD2kiILIsbyz2V0Hn4lFUY&m=uLWb19rS_9IrFOaSAkQeNfJ1qv_6HGtvzKSj16TxYN8&s=iQFFPiu77Qwcm1tmAu9f-H9-0rZQOG8HFgkRIUXvgs0&e=
Stefan
     raster map
J
Dr. Jim Maas
https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.osgeo.org_mailman_listinfo_grass-2Duser&d=CwIGaQ&c=DsZY2bea7iNIzyp-7sZ0t0F2UfNQZUfZhEPCv_2wBI0&r=O31ltou6ygJL2Y01kQyNJJD2kiILIsbyz2V0Hn4lFUY&m=uLWb19rS_9IrFOaSAkQeNfJ1qv_6HGtvzKSj16TxYN8&s=1QihHldi_jAaJN_Jzs5qtFb-hG4ZZFYRLI7AhntJ1bk&e=
Dr. Jim Maas
The information contained in this email message is intended only for the use of the individual(s) to whom it is addressed and may contain information that is privileged and sensitive. If you are not the intended recipient, or otherwise have received this communication in error, please notify the sender immediately by email at the above referenced address and note that any further dissemination, distribution or copying of this communication is strictly prohibited.
The U.S. Export Control Laws regulate the export and re-export of technology originating in the United States. This includes the electronic transmission of information and software to foreign countries and to certain foreign nationals. Recipient agrees to abide by these laws and their regulations -- including the U.S. Department of Commerce Export Administration Regulations and the U.S. Department of State International Traffic in Arms Regulations -- and not to transfer, by electronic transmission or otherwise, any content derived from this email to either a foreign national or a foreign destination in violation of such laws.
Jim - one other thought...
If you look at r.stream.distance, you see that internally it finds the stream outlet. Unfortunately it does not report it but if you go into the source python script, you can see how it is calculated and extract that bit of code for your own script. I've done similar translating the python into a POSIX (sh) script (mainly because I suck at python...lol).
Chris
Engineer/Scientist
ENSCO, Inc.
Hi Stefan,
Thanks a bunch,
J
Stefan
     raster map
J
Dr. Jim Maas
Dr. Jim Maas
Hi Jim,
If I understood you final objective correctly, I would say 2: r.stream.basins, will replace most of your workflow...
With the stream_rast option, r.stream.basisns produces basins using raster input maps with "multiple outlets".
You can feed this option either with a raster map of your whole stream (which naturally covers the outlet) or even specify categories of the streams you want to get the basisns for. Citing from the manual:
To delineate one or more particular basins defined by given streams, add simply stream categories:
r.stream.basins -lc direction=direction stream_rast=streams cats=2,7,184 basins=bas_basin
See also: https://grasswiki.osgeo.org/wiki/R.stream.*_modules and of course the related scientific paper: http://www.sciencedirect.com/science/article/pii/S0098300411000975
Hope that helps.
Stefan
Sent: 26. april 2016 15:44
To: Blumentrath, Stefan <Stefan.Blumentrath@nina.no>; grass-user@lists.osgeo.org
Hi Stefan,
Thanks a bunch,
J
Stefan
Of Jim Maas
     raster map
J
Dr. Jim Maas
Dr. Jim Maas
Thanks Stefan,
I guess I should have mentioned, the whole point of all this work is to get the appropriate input data, including the topidx map required to run topmodel for a two year period, on very small catchments (25km^2 ). I can run either the GRASS or R version of topmodel, but it appears that the R version is better equipped to do sensitivity analysis, i.e. pass it a parameters file with multiple lines of parameters, through which it will iterate and do the sensitivity analysis. I'm assuming this doesn't change your advice?
Thanks
J
On 26/04/16 22:10, Blumentrath, Stefan wrote:
Hi Jim,
Hope that helps.
Stefan
Hi Stefan,
Thanks a bunch,
J
Stefan
Of Jim Maas
      raster map
J
Dr. Jim Maas
Dr. Jim Maas
Dr. Jim Maas
Mathematical Modelling in
Epidemiology of Infectious Disease
Rm 2.13 MED
Norwich Medical School
Norwich Research Park,
NR4 7TJ U.K.
E: j.maas@uea.ac.uk
