Dear all,
Apologies, sent to the developer mailing list by mistake.
I am trying to save a rather large file from GRASS
Versions:
GRASS GIS 8.2.1
GDAL 3.6.3, released 2023/03/07
Linux: almalinux:9.1
The size of the file is:
rows=141120
cols=362880
cells=51209625600
This the command
r.out.gdal -c input=out output=output.tif format=COG type=Int16 createopt=COMPRESS=LZW,PREDICTOR=2,BIGTIFF=YES --overwrite --quiet
This the output
Warning 6: driver MEM does not support creation option COMPRESS
Warning 6: driver MEM does not support creation option PREDICTOR
Warning 6: driver MEM does not support creation option BIGTIFF
ERROR 2: /usr/gdal-3.6.2/frmts/mem/memdataset.cpp, 1289: cannot allocate 1x102419251200 bytes
ERROR: Unable to create dataset using memory raster driver
Is there any option not to use the MEM driver when writing to disk?
Thanks
Laura
Hi Laura,
On Thu, Jun 15, 2023 at 5:00 PM Laura Poggio <laura.poggio@gmail.com> wrote:
Dear all,
Versions:
GRASS GIS 8.2.1
rows=141120
cols=362880
cells=51209625600
This the command
This the output
I am not sure, in this code section it doesn't look like this:
https://github.com/OSGeo/grass/blob/51e962abbc1176211ad2c4cb7857a61a2b6d1c6f/raster/r.out.gdal/main.c#L377
Maybe someone else in the list has more insights?
Some options:
- try first the GTiff driver, then convert to COG with gdal_translate
- enlarge RAM using a swap file (no reboot needed but sudo access
needed) as disk space is relatively cheap and r.out.gdal will not
realize then that it gets swapped.
Best,
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
Dear Markus,
Using GTiff (in grass version 8.3.0 and with gdal 3.7.1) solved the problem. I get a compressed file and the use of RAM is acceptable. I still get the same errors when using COG.
A quick test with a different file in grass 8.2.1 and gdal 3.6.4 (previous configuration) indicates that it would be the same there, but I could not test it with the original file because of some hardware issues.
Thanks a lot!
Laura
On Thu, 22 Jun 2023 at 09:16, Markus Neteler <neteler@osgeo.org> wrote:
Hi Laura,
Dear all,
Versions:
GRASS GIS 8.2.1
rows=141120
cols=362880
cells=51209625600
This the command
This the output
I am not sure, in this code section it doesn’t look like this:
Some options:
Best,
Markus Neteler, PhD
