Help me please! I have a set of contours, which are created from raster cropped by the mask.
After smoothing the contours with “v.generalize method=boyle look_ahead=5”, I get the following result.
Hello,
but do original, unsmoothed vector also contains two lines?
Where those lines generated in GRASS or some other (not so
intelligent) software?
If manual splitting and deleting unnecessary parts is not an option,
I would suggest to play around with v.clean. Don't forget to make a
backup, as it might take lots of experiments to find the right
combination.
Maris.
2012/6/21 Dmitriy Tyugaev <dtyugaev@gmail.com>:
Hi list,
After smoothing the contours with "v.generalize method=boyle look_ahead=5",
