[GRASS-user] starspan with grass support compilation failure
Not sure if I should post this here. I have a problem compiling starspan
with support for GRASS.
# configuring reports no problems
./configure --with-grass=/usr/local/grass-6.5.svn
# attempt to compile...
make
src/stats/Stats.cc:232: error: ‘sort’ was not declared in this scope
make: *** [Stats.o] Error 1
The same problem appears also with a bare "./configure".
Does anybody else face problems currently with starspan?
Nikos
make
The same error appears with all of the three versions of starspan
1.2.01, 1.2.02, 1.2.03.
Perhaps it's not starspan-related.
Nikos
On Thu, Jan 29, 2009 at 4:22 AM, Nikos Alexandris
make
src/stats/Stats.cc:232: error: 'sort' was not declared in this scope
Hmm. Check the archives for Jonathan Greenberg -- he is one of the
lead developers. It would be nice to get starspan into OSGEO so that
questions / code patches ect. can be handled in an efficient manner.
Starspan is an emmensly important GIS tool, but suffers from a lack of
developers, documentation, and bug handling.
Perhaps I should take these comments to the OSGEO mailing list... What
do you think Jonathan?
Dylan
>> make
Dylan
Yes, it would be very nice to have starspan osgeo-integrated.
Please... :slight_smile:
Folks:
    I would LOVE to see someone take over development on starspan -- I did submit a OSGEO application but it came back denied, more or less, because of lack of community support. There are a lot of bugs and user interface issues still remaining that would be nice to get cleaned up, but I'm not a C programmer and, while I developed the algorithm itself, I was not the coder.
    If anyone is interested in working on the development, please email me! If you all are not sure what STARSPAN does, it is a flexible way to get raster data (raw or summarized) associated with vector coverages (similar to Arc's zonalstats, although with more output types). E.g., if you want to get the average pixel values from a SET of raster images underlying a single vector coverage, starspan will spit out a CSV containing the vector's original database, along with a column for the average pixel value for that polygon. The algorithm tends to be very fast, especially in cases where the polygon coverage is a fraction of the raster coverage (which tends to be the case in many problems).
--j
make
Dylan
On Thu, 2009-01-29 at 10:15 -0800, Jonathan Greenberg wrote:
Folks:
--j
Jonathan + all,
please excuse my ignorance if I ask something that I shouldn't: could
you imagine starspan as part of GRASS? Something like "v.starspan" ?
Kind regards, Nikos
Folks:
--j
Jonathan + all,
http://lists.osgeo.org/pipermail/grass-user/2008-July/045882.html
http://lists.osgeo.org/pipermail/grass-user/2008-August/045886.html
+1
Moritz
Hello Nikos,
probably create a trac wish report "Investigate Starspan integration
possibilities into GRASS". It can be used also later as meta bug to
track integration blocking code bugs.
I haven't used Starspan and currently have no requirements to do so,
still integrating various small projects into larger ones is a good
thing - lessens work fragmentation and improves code handling - any
GRASS dev can poke around that code.
Maris.
2009/1/30, Moritz Lennert <mlennert@club.worldonline.be>:
Folks:
--j
Jonathan + all,
+1
Moritz
grass-user mailing list
grass-user@lists.osgeo.org
Speaking as a user...
I used starspan a couple of times and it's great. But what I most
liked about it is that _it works outside of GRASS_! It's independent
of GRASS, so an user with just a shapefile and some GeoTiffs can use
it happily.
At the same time that I believe it's a great tool and it should
receive more attention, the ability to work with other formats and
outside of grass is very important. Maybe have something like the gdal
tools, where the user can transform and query any image outside grass
but also, it works inside the GIS.
I say this because I had several grass rasters that I needed to do a
zonal stats with a very big shapefile. I was having a hard time
importing the shapefile into grass so, starspan to the rescue! Fast
and simple.
Just my 2c
Daniel
On Fri, Jan 30, 2009 at 7:48 AM, Maris Nartiss <maris.gis@gmail.com> wrote:
Hello Nikos,
Maris.
Folks:
--j
Jonathan + all,
+1
Moritz
On Fri, Jan 30, 2009 at 11:30 AM, Daniel Victoria
Sidenote:
There is new activity ongoing to improve that situation:
http://trac.osgeo.org/grass/ticket/426
