Some time ago launching GRASS 6.3.0RC4 under Ubuntu in text mode [1]
gave twice a print-out of:
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
Now GRASS 6.3.1svn gives the same double print-out while GRASS 6.4.svn
print's out only once!
Is it still an Ubuntu-issue?
[1] http://www.nabble.com/When-starting-grass-in-text-mode%
2C-why...---(Question-of-minor-importance)-td14895992.html
On Sun, Aug 3, 2008 at 1:30 PM, Nikos Alexandris
[1] http://www.nabble.com/When-starting-grass-in-text-mode%2C-why…—(Question-of-minor-importance)-td14895992.html
Did you verify this?
http://www.nabble.com/Re%3A--GRASS-user--Ubuntu-6.06-Dapper%3A-strange-sudo-hints-printed-a-tstartup-p5691527.html
Thanks Markus. It works. Note the "typo" in http://www.nabble.com/RE%
3A-strange-sudo-hints-printed-a-tstartup-td5691550.html#a5691527: It is
"successful" otherwise it wont work.
Schoene Gruesse, Nikos
