Hi!
Soory but I cannot completly understand it:
GRASS 6.3.svn (polska):~ > v.to.points -n input=mrog_vector output=zb_point type=point,line, llayer=1 dmax=100
DBMI-Postgres driver error:
Cannot select:
select * from mrog_5 where 0 = 1
ERROR: relation "mrog_5" does not exist
Warning:Cannot open select cursor: 'select * from mrog_5 where 0 = 1'
ERROR:Cannot copy table
the input is mrog_vector
error concerns completly different table, which realy don't exist
Jarek
2008/6/12 Jarosław Jasiewicz <jarekj@amu.edu.pl>:
Cannot select:
what
v.db.connect mrog_vector -p
says?
Probably you have accidently linked not existing table 'mrog_5' to the
vector map.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
Martin Landa pisze:
2008/6/12 Jaros³aw Jasiewicz <jarekj@amu.edu.pl>:
Cannot select:
what
says?
vector map.
Martin
v.db.connect -p says that no table is connected, in general I know nothing about mrog_5 I have never create it.
adationally when I tried to add empty table the same message appear
I remove the vector and import it again, I thing it was accident error due to some unknown circumstances, but why v.to.points became crazy?
On Thu, 2008-06-12 at 14:07 +0200, Jarosław Jasiewicz wrote:
Martin Landa pisze:
> Hi,
>> Cannot select:
> what
> says?
> vector map.
> Martin
Jarek,
you already where connected (using db.connect) while importing your
vector map in the GRASS' database?
Nikos
