[GRASS-user] sum of several raster maps
I have several Raster Maps (1 - 365). I would like to create one map by adding all these maps together.
Is there any function to do so without using
r.mapcalc map = map1 + map2 + map3....+map365
Grettings.
Andi
"Feel free" - 10 GB Mailbox, 100 FreeSMS/Monat ...
Jetzt GMX TopMail testen: http://www.gmx.net/de/go/topmail
Andi Jochem wrote on 04/19/2007 03:40 PM:
You can use r.series. See
   g.manual r.series
for an example with wildcards.
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
Hi Andi,
On Thu, 19 Apr 2007 15:40:28 +0200
"Andi Jochem" <Andruit@gmx.de> wrote:
what about r.series input=map1,map2,map3,.. method=sum ?
regards,
  Otto
Grettings.
Andi
On Apr 19 [15:40], Andi Jochem wrote:
why not use r.mapcalc?
$ str="r.mapcalc map = map1"
$ for i in `seq 2 365`; do str=$str+" + map$i"; done
$ $str
\f.
Florian Kindl
Institute of Geography
University of Innsbruck
Note prior to GRASS 6.2 there was a limit on the maximum number of open
files in lib/gis/G.h (256), but that has since been removed. You used to
have to increase that number to 400 or so and recompile GRASS to use
that many maps. Also the number of open files must be smaller than the
operating system's limit. (Given by `cat /proc/sys/fs/file-max` in Linux
2.4) See the comments in raster/r.patch/nfiles.h in the source code.
(can we increase or remove the limit in r.patch now?)
g.mlist is your friend for constructing a comma separated list of input
maps.
Hamish
I've removed the limit from r.patch.
