Hello
I would like to use the procedure described in "Open Source GIS: A
GRASS GIS Approach" second edition page 191 "7.3.5 Surfaces with
faults".
I have a survey of points. Some points are two ditches. I have run a
v.surf.rst with the survey points without the ditch.
Attached is the ascii file of the ditch points (EPSG:32632)
I have therefore operated as follows:
Command ended with non-zero return code -11 (0 sec)
I believe there was something wrong in v.in.lines or in my ASCII file:
the vector line hasn't attribute
Il giorno lun, 24/07/2023 alle 16.44 +0200, bonushenricus ha scritto:
Hello
faults".
> v.in.lines -z --overwrite input=fosso.dat output=fosso_linea /
> separator=comma
> g.region vector=fosso_linea res=0.2
> v.to.rast -d --overwrite input=fosso_linea type=line output=fosso /
> use=z
> v.surf.rst --overwrite segmax=60 npmin=100 dmin=1 dmax=6 /
> input=fosso_linea elevation=fosso_dem mask=fosso
the result is with no_data
Ok
v.to.points creates 2 layer.
The good layer is the 2.
So with
v.to.rast -d input=fosso_punti type=point layer=2 output=fosso_dem
use=z
is correct.
I prefered the way with v.surf.rst from my original survey points, but
the way with v.to.points can help me.
Il giorno lun, 24/07/2023 alle 17.59 +0200, bonushenricus ha scritto:
Hello
I've just tried with the solution of this thread https://www.mail-archive.com/grass-user@lists.osgeo.org/msg40640.html
so
> separator=comma
> v.split input=fosso_linea output=fosso_linea_split length=0.2
> v.to.points -i input=fosso_linea_split output=fosso_punti
> v.to.rast -d input=fosso_punti type=point output=fosso_dem use=z
but the result is
file:
> Hello
> faults".
> a
> > separator=comma
> > use=z
> Some suggestions?
Hello
the problem isn't in my ASCII file or in v.in.lines
but a bug in v.to.rast, with the -d parameter.
I used gdb
Thread 1 "v.to.rast" received signal SIGSEGV, Segmentation fault.
(gdb) bt #0 0x0000000000000000 in ?? () #1 0x00007ffff7ef7091 in G_plot_point ()
from /usr/local/grass83/lib/libgrass_gis.8.3.so
#2 0x0000555555558d46 in do_lines () #3 0x000055555555abc6 in vect_to_rast () #4 0x0000555555557ad6 in main ()
(gdb)
Hello
so
> separator=comma
but the result is
file:
> Hello
> faults".
> a
> > separator=comma
> > use=z
> Some suggestions?
Hello
I used gdb
> (gdb) bt
> (gdb)
> Hello
> so
> > separator=comma
> but the result is
> file:
> > Hello
> > faults".
> > a
> > > separator=comma
> > > use=z
> > Some suggestions?
grass-user mailing list
grass-user@lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/grass-user
Il giorno mar, 25/07/2023 alle 08.33 +0300, Maris Nartiss ha scritto:
Please provide your input data and computational region settings. I
was not able to reproduce the issue with my data.
Māris.
otrd., 2023. g. 25. jūl., plkst. 07:17 — lietotājs bonushenricus
(<bonushenricus76@gmail.com>) rakstīja:
> Hello
> I used gdb
> > (gdb) bt
> > (gdb)
> scritto:
> > Hello
> > so
> > > separator=comma
> > > use=z
> > but the result is
> > file:
> > scritto:
> > > Hello
> > > GIS: A
> > > with
> > > faults".
> > > run
> > > a
> > > > separator=comma
> > > > output=fosso
> > > > use=z
> > > Some suggestions?
ns_res=0.1 elevation=fosso_dem_rst@granello overlap=2 tension=40.
but the result in width of the line is too big
and also the profile is with "terraces"
Māris.
> Hello
> I used gdb
> > (gdb) bt
> > (gdb)
> scritto:
> > Hello
> > so
> > > separator=comma
> > > use=z
> > but the result is
> > file:
> > scritto:
> > > Hello
> > > GIS: A
> > > with
> > > faults".
> > > run
> > > a
> > > > separator=comma
> > > > output=fosso
> > > > use=z
> > > Some suggestions?
And at the end I found the solutions:
after a v.to.rast at the desired resolution
I can choose the line width with r.buffer
and at the end I can use v.surf.rst, with raster line mask
Il giorno mar, 25/07/2023 alle 06.17 +0200, bonushenricus ha scritto:
Hello
I used gdb
> (gdb) bt
> (gdb)
> Hello
> so
> > separator=comma
> but the result is
> file:
> scritto:
> > Hello
> > A
> > faults".
> > run
> > a
> > > separator=comma
> > > output=fosso
> > > use=z
> > Some suggestions?
> Māris.
> > Hello
> > I used gdb
> > > (gdb) bt
> > > (gdb)
> > scritto:
> > > Hello
> > > so
> > > > separator=comma
> > > > use=z
> > > but the result is
> > > file:
> > > scritto:
> > > > Hello
> > > > GIS: A
> > > > with
> > > > faults".
> > > > run
> > > > a
> > > > > separator=comma
> > > > > output=fosso
> > > > > use=z
> > > > Some suggestions?
> > _______________________________________________
