[GRASS-user] temporary layer creation
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
I want to need to create a temporary raster layer - is there a
function to create a unique name for this raster?
Thanks
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk6BtxQACgkQoYgNqgF2egpRRACeMw2Rfu+lz+gDvoBlG4Wka0zx
BZYAoICB0Qu2NkDu8xFvUuahfztmriGR
=gpcF
-----END PGP SIGNATURE-----
Hash: SHA1
Hi
Check
http://grass.osgeo.org/wiki/Parallel_GRASS_jobs#The_Grid_Engine_script
# generate machine (blade) unique TMP string
UNIQUE=`mktemp`
MYTMP=`basename $UNIQUE`
"mktemp" is part of "coreutils" on my Linux machine (maybe use it with
--dry-run).
Hash: SHA1
wrote:
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Hi I want to need to create a temporary raster layer - is there
a function to create a unique name for this raster?
Check
# generate machine (blade) unique TMP string UNIQUE=`mktemp`
MYTMP=`basename $UNIQUE` ...
with --dry-run).
Thanks - that's an idea. But if I see it correctly, you use it to
create a temporary mapset - I would only need a temporary raster - is
there an easier way to achieve that, apart from checking in (one of
the) the directory where the rasters are stored?
Rainer
South Africa
Skype: RMkrug
iEYEARECAAYFAk6B8qwACgkQoYgNqgF2egr1GQCfZzHpKXCL9B1PzhPCTNIgcjAG
IHMAnA7LprGPhtewNAx2x+llVDjYF4FG
=ZUUG
Hash: SHA1
Check
with --dry-run).
The idea was to generate a machine unique name. That can be
used for anything then since it is in the $MYTMP variable.
Most scripts create a name based upon the name of the script, the PID
(obtained from the shell variable $$), and ".tmp".
