[GRASS-user] Tessellation of a set of polygons
Let’s consider a set of input polygons (represented by dark gray polygonal footprints in the enclosed screenshot [1]). I wonder whether there already exists a (set of) GRASS instructions to produce the “surrounding tessellation”. I mean, could you please tell me how to compute the set of multicolor polygons in the enclosed screenshot?
As an example, the blue polygon is the set of points that are:
  • overlayed by the dark gray polygon labeled #1
  • or closer to the dark gray polygon labeled #1 than to any other input polygon.
Thanks a lot for any help/advice.
Thomas Leduc
PS: I’m aware there already exist in GRASS some functions such as “v.to.rast, r.grow.distance, and r.contour” which could help in building map of distances, and isocontours… I’m also aware there already exist “v.to.rast, r.thin, and r.to.vect feature=line” to build some sort of medial axis transform or skeleton.
PPS: input data set
create table b(gid int, the_geom GEOMETRY(POLYGON, 2D));
insert into b values (0, GeomFromText(‘POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0))’));
insert into b values (1, GeomFromText(‘POLYGON ((30 0, 30 -30, 10 -30, 10 -40, 40 -40, 40 0, 30 0))’));
insert into b values (2, GeomFromText(‘POLYGON ((20 20, 100 20, 100 40, 60 40, 60 30, 40 30, 40 60, 20 60, 20 20))’));
insert into b values (3, GeomFromText(‘POLYGON ((60 10, 60 -20, 100 -10, 100 10, 60 10))’));
insert into b values (4, GeomFromText(‘POLYGON ((-10 -10, -10 -40, -40 -40, -40 -20, -60 -20, -60 0, -50 0, -50 -10, -10 -10))’));
insert into b values (5, GeomFromText(‘POLYGON ((-40 20, -40 40, -10 40, -10 30, -20 20, -40 20))’));
[1] this screenshot of about 11 KB is also downloadable at https://dl.dropboxusercontent.com/u/8846569/tessellation.png
(attachments)
On 29/08/13 17:38, Thomas Leduc wrote:
Let's consider a set of input polygons (represented by dark gray
"surrounding tessellation". I mean, could you please tell me how to
   - overlayed by the dark gray polygon labeled #1
   - or closer to the dark gray polygon labeled #1 than to any other
input polygon.
You could try the following workflow:
- add category values to your boundaries (if that is important make them equal to the cat values of your centroids, otherwise just using v.category op=add type=boundary)
- use v.to.points to transform the boundaries to points (each point will have the cat value of the corresponding boundary)
- v.voronoi to create voronoir diagrams for these points
- v.dissolve to disolve boundaries between polyons with the same category numbers
Moritz
On Thu, Aug 29, 2013 at 5:38 PM, Thomas Leduc
<thomas.leduc@cerma.archi.fr> wrote:
Let's consider a set of input polygons (represented by dark gray polygonal
exists a (set of) GRASS instructions to produce the "surrounding
tessellation". I mean, could you please tell me how to compute the set of
  - or closer to the dark gray polygon labeled #1 than to any other input
polygon.
I have added tessellation of areas to v.voronoi in trunk r57621. You
need to use the new -a flag and can control the smoothness of the
output with the new segment option. With your example, segment=0.15
produces reasonably smooth output.
This implementation ignores shared boundaries (not present in your
example) which would need to be patched in afterwards. An alternative
would be to use v.overlay to obtain areas outside the original input
areas.
HTH,
Markus M
Thomas Leduc
PS: I'm aware there already exist in GRASS some functions such as
"v.to.rast, r.grow.distance, and r.contour" which could help in building map
of distances, and isocontours... I'm also aware there already exist
"v.to.rast, r.thin, and r.to.vect feature=line" to build some sort of medial
PPS: input data set
insert into b values (0, GeomFromText('POLYGON ((0 0, 10 0, 10 10, 0 10, 0
0))'));
insert into b values (1, GeomFromText('POLYGON ((30 0, 30 -30, 10 -30, 10
-40, 40 -40, 40 0, 30 0))'));
insert into b values (2, GeomFromText('POLYGON ((20 20, 100 20, 100 40, 60
40, 60 30, 40 30, 40 60, 20 60, 20 20))'));
insert into b values (3, GeomFromText('POLYGON ((60 10, 60 -20, 100 -10, 100
10, 60 10))'));
insert into b values (4, GeomFromText('POLYGON ((-10 -10, -10 -40, -40 -40,
-40 -20, -60 -20, -60 0, -50 0, -50 -10, -10 -10))'));
insert into b values (5, GeomFromText('POLYGON ((-40 20, -40 40, -10 40, -10
30, -20 20, -40 20))'));
grass-user mailing list
grass-user@lists.osgeo.org
Dear Moritz,
Thanks a lot for your quick answer and sorry for my own “latency”. Yes, indeed, the Medial Axis Transform (or Skeleton) of Polygons dataset can be computed via the Voronoi diagram of the corresponding set of points (discretizing the polygons boundaries). However, I assume that this is not a scalable solution with a huge set of polygons (insofar as the v.to.points resolution has to be of enough fine grain). I was thinking to a morphological thinning based solution… Maybe I’m wrong.
With GRASS GIS 6.4.0+42329, and the enclosed (small) dataset, the tessel.shp output file does not match expectations. Could you please tell me where I’m wrong?
g.remove vect=buildings,newbuildings,vor,tessel
v.in.ogr dsn=/tmp/src/src.shp output=buildings
g.region vect=buildings
v.category input=buildings output=newbuildings option=add type=boundary
v.out.ogr input=newbuildings type=boundary dsn=/tmp/src olayer=build layer=1 format=ESRI_Shapefile
v.to.points -i --overwrite input=newbuildings output=newbuildings_pts dmax=0.1
v.out.ogr input=newbuildings_pts type=point dsn=/tmp/src olayer=pts layer=1 format=ESRI_Shapefile
v.voronoi -l --overwrite input=newbuildings_pts output=vor
v.out.ogr input=vor type=line dsn=/tmp/src olayer=vor layer=1 format=ESRI_Shapefile
v.dissolve input=vor output=tessel
v.out.ogr input=tessel type=line dsn=/tmp/src olayer=tessel layer=1 format=ESRI_Shapefile
Thanks a lot once again for your help.
Thomas Leduc
(attachments)
src.zip (917 Bytes)
On Mon, Sep 2, 2013 at 3:13 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
    input polygon.
  • add category values to your boundaries (if that is important make them equal to the cat values of your centroids, otherwise just using v.category op=add type=boundary)
  • use v.to.points to transform the boundaries to points (each point will have the cat value of the corresponding boundary)
  • v.voronoi to create voronoir diagrams for these points
  • v.dissolve to disolve boundaries between polyons with the same category numbers
Moritz
Thomas LEDUC
On Mon, Sep 9, 2013 at 4:23 PM, Thomas Leduc
Dear Moritz,
Thanks a lot for your quick answer and sorry for my own "latency". Yes,
morphological thinning based solution... Maybe I'm wrong.
Can you elaborate on a morphological thinning based solution? Given
some references, it could be implemented.
There are 3 known bugs in v.voronoi [0, 1, 2]. All have been fixed in
GRASS 7. That means as long as you use GRASS 6, results of v.voronoi
might be wrong. You are welcome to test GRASS 7 and push for the
backport of the relevant fixes;)
Markus M
[0] https://trac.osgeo.org/grass/ticket/957
[1] https://trac.osgeo.org/grass/ticket/1682
[2] https://trac.osgeo.org/grass/ticket/2019
dmax=0.1
Thomas Leduc
input polygon.
numbers
Moritz
Thomas LEDUC
Dear Markus,
Impressive responsiveness. Thanks for the dedicated development. http://trac.osgeo.org/grass/changeset/57621 is fully operative on the given dataset.
It took me some time to test it, because I’m a complete newby with GRASS community. Just to keep it written somewhere, I first had to checkout, configure, compile, and install GRASS7 snapshot on my Debian 6.0.7:
svn checkout https://svn.osgeo.org/grass/grass/trunk grass7_trunk
cd ./grass7_trunk
./configure --enable-64bit -with-freetype-includes=/usr/include/freetype2 --prefix=/usr/local/misc/grass7-snapshot --with-sqlite
make
make install
Then, in the GRASS console, I’ve copied and pasted the following instructions:
g.remove vect=buildings,vor
v.in.ogr -o dsn=/tmp/src/src.shp output=buildings
v.voronoi -a --overwrite input=buildings output=vor segment=0.15
v.out.ogr --overwrite input=vor type=area dsn=/tmp/src olayer=vor layer=1 format=ESRI_Shapefile
Many thanks once again.
Thomas
On Sun, Sep 8, 2013 at 7:49 PM, Markus Metz <markus.metz.giswork@gmail.com> wrote:
    polygon.
areas.
HTH,
Markus M
Thomas Leduc
PPS: input data set
0))’));
10, 60 10))’));
Thomas LEDUC
Hi Thomas,
just curious (given that GRASS GIS 7 now offers this functionality),
with which GIS software did you create your example?
best,
markusN
MarkusN:
To make a guess I'd say it looks like v.to.rast + r.grow + r.to.vect.
(note the gridding artifacts)
Hamish
Hi Markus,
I’ve produced the screenshot using Gearscape 0.2b4 (http://gearscape.fergonco.es/index.php/downloads/2 - Thanks to Fernando Gonzalez Cortes) and a small dedicated development that I’ve written in Java. This implementation is based on JTS library (in particular, SpatialIndex and Polygonizer classes), and it starts by a rasterization of the set of input polygons.
Thomas
On Tue, Sep 10, 2013 at 9:41 PM, Markus Neteler <neteler@osgeo.org> wrote:
Hi Thomas,
best,
markusN
Thomas LEDUC
Dear Hamish,
Yes indeed, the following script produces some equivalent result (but as explained before, this is not the solution I used):
g.remove vect=buildings,plots rast=buildings_r,plots_r
g.region vect=buildings nsres=0.25 ewres=0.25
v.to.rast --overwrite input=buildings output=buildings_r use=attr attrcolumn=gid
r.grow --overwrite input=buildings_r output=plots_r metric=euclidean radius=120
r.to.vect --o input=plots_r output=plots type=area
v.out.ogr --o input=plots type=area dsn=/tmp/src olayer=plots layer=1 format=ESRI_Shapefile
MarkusN:
To make a guess I’d say it looks like v.to.rast + r.grow + r.to.vect.
Hamish
Thomas LEDUC
Dear GRASS-users & developpers,
As summed up below, I’ve tried to tessellate the enclosed datasource (a shapefile composed of several building footprints) using 2 different approaches:
v.in.ogr -o dsn=/tmp/buildings.shp output=buildings
1st method:
v.voronoi -a --overwrite input=buildings output=vor smoothness=0.15
2nd method:
r.grow --overwrite input=buildings_r output=plots_r metric=euclidean radius=4800
As may be observed with the screenshot, (both) output results does not match expectations.
Do you have any idea of the reason why it’s wrong?
Many thanks for your help,
Thomas
Inline image 1
(attachments)
buildings.zip (71.1 KB)
On Tue, Sep 10, 2013 at 3:10 PM, Thomas Leduc <thomas.leduc@cerma.archi.fr> wrote:
Dear Markus,
cd ./grass7_trunk
make
make install
Thomas
Thomas LEDUC
    polygon.
areas.
HTH,
Markus M
Thomas Leduc
PPS: input data set
0))’));
10, 60 10))’));
Thomas LEDUC
I’ve used Theissen/Voroni polygons but tessellation is new to me, not surprising given my state of knowledge so I would appreciate how it differs from T/V polygons for my edification.
Thanks in advance,
Lyle Browning
Dear Markus,
cd ./grass7_trunk
make
make install
Thomas
Thomas LEDUC
    polygon.
areas.
HTH,
Markus M
Thomas Leduc
PPS: input data set
0))’));
10, 60 10))’));
Thomas LEDUC
As summed up below, I've tried to tessellate the enclosed datasource (a
shapefile
It would help if you gave us the projection info for that dataset.
Moritz
Thanks a lot for your concern. Please find enclosed the corresponding .prj file.
(attachments)
buildings_bdt.prj (428 Bytes)
On Thu, Feb 27, 2014 at 10:09 AM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
shapefile
Moritz
Thomas LEDUC
.prj file.
I don't have time to look into this any further right now, but the import of the file reports a series of topological errors. You might want to check on those, first.
Moritz
On Thu, Feb 27, 2014 at 1:03 PM, Moritz Lennert
.prj file.
those, first.
The shapefile is 3D. The topological errors disappear if the import is
forced to 2D with v.in.ogr -2. The tesselation is only 2D anyway.
Markus M
Moritz
Yes indeed Markus, tessellation’s problem disappears if import is forced to 2D (with v.in.ogr -2).
Thanks for your answer.
Thomas
PS: A workaround solution would have been to produce first internal buffers of areas (with negative distance, i.e. v.buffer distance=-.25 type=area)
On Thu, Feb 27, 2014 at 1:58 PM, Markus Metz <markus.metz.giswork@gmail.com> wrote:
.prj file.
I don’t have time to look into this any further right now, but the import of
those, first.
Markus M
Moritz
Thomas LEDUC
