Thanks Mark,
I follow the steps from http://www.les-ejk.cz/ubuntu/
The first 2 steps was going ok.
However, at the third step, I face the trouble:
dtat@dtat-desktop:~$ sudo apt-get update
Hit http://security.ubuntu.com hardy-security Release.gpg
Ign http://security.ubuntu.com hardy-security/main Translation-en_US
................. (things done OK!)
Ign http://vn.archive.ubuntu.com hardy-updates/multiverse Translation-en_US
Hit http://vn.archive.ubuntu.com hardy Release
Hit http://vn.archive.ubuntu.com hardy-updates/multiverse Sources
E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the
problem.
Sorry for a long message, but finally, it is:
problem.
I wonder how can I solve this trouble.
I am looking for your further help.
Best regards,
Tri Van
This message was sent using IMP, the Internet Messaging Program.
On Mon, 2008-10-20 at 00:07 +0700, Van PD Tri wrote:
Thanks Mark,
to correct the
problem.
to correct the
problem.
Best regards,
Tri Van
Hi Tri Van.
You probably need to execute within from a terminal the command "sudo
dpkg --configure -a", as the error message suggests. Post back if this
does not solve the problem.
Kind regards, Nikos
P.S. Please reply in the same thread (even if you have to reply to
yourself) rather than starting a new thread. This way it will be easier
for other people to read and understand the the thread and, why not,
find the solution if they face the same problem.
