I am trying to read some netCDF data (from the CRU climate database) into grass. I am looking at the netcdf wiki page and having a little trouble translating the instructions there to the output I am getting from “gdalinfo”. Here is the
If I am trying to use syntax that looks something like:
r.in.gdal input=NETCDF:"sst.nc":time_bnds output=sst
I am getting the following error:
ERROR 4: `NETCDF:~/Downloads/cru_ts_3_10.1901.2009.pet.dat.nc:time_bnds’ does not exist in the file system,
and is not recognised as a supported dataset name.
In my case, the PATH_TO_FILE is
“~/Downloads/cru_ts_3_10.1901.2009.pet.dat.nc”
However, I can’t tell what to use in the place of “:time_bnds”. Any ideas from the pasted text below of what my input argument should look like?
Thanks in advance,
Kirk
Here is output I am looking at from gdalinfo:
GRASS 6.4.1 (globe_30min):~ > gdalinfo ~/Downloads/cru_ts_3_10.1901.2009.pet.dat.nc
ERROR 1: GDAL/GRASS57 driver was compiled against GDAL 1.8 but current library version is 1.9
Driver: netCDF/Network Common Data Format
Files: /Network/Servers/truffula.fr.umn.edu/Volumes/disk1/home1/kirkw/Downloads/cru_ts_3_10.1901.2009.pet.dat.nc
Size is 720, 360
Coordinate System is `’
Origin = (-180.000000000000000,90.000000000000000)
Pixel Size = (0.500000000000000,-0.500000000000000)
Metadata:
lat#long_name=latitude
lat#units=degrees_north
lon#long_name=longitude
lon#units=degrees_east
NC_GLOBAL#comment=Data restrictions: for academic research use only.Contact BADC for details
NC_GLOBAL#contact=BADC <badc@rl.ac.uk>
NC_GLOBAL#Conventions=CF-1.4
NC_GLOBAL#history=Wed Feb 2 03:32:36 GMT 2011 : User badc : Program makegridsauto.for called by update.for
NC_GLOBAL#institution=Data held at British Atmospheric Data Centre, RAL, UK.
NC_GLOBAL#references=Information on the data is available at http://badc.nerc.ac.uk/data/cru/
NC_GLOBAL#source=Run ID = 1102011219
Data generated by BADC from:
tmp.1009221824.dtb
dtr.1009221824.dtb
vap.1009221824.dtb
cld.1009221824.dtb
NC_GLOBAL#title=CRU TS 3.10 Potential Evapotranspiration
pet#_FillValue=9.969209968386869e+36
pet#correlation_decay_distance=-999
pet#long_name=potential evapotranspiration
pet#missing_value=9.969209968386869e+36
pet#units=mm
time#calendar=gregorian
time#long_name=time
time#units=days since 1900-1-1
Corner Coordinates:
Upper Left (-180.0000000, 90.0000000)
Lower Left (-180.0000000, -90.0000000)
Upper Right ( 180.0000000, 90.0000000)
Lower Right ( 180.0000000, -90.0000000)
Center ( 0.0000000, 0.0000000)
Band 1 Block=720x1 Type=Float64, ColorInterp=Undefined
NoData Value=9.96920996838686905e+36
Metadata:
NETCDF_DIMENSION_time=380
NETCDF_time_units=days since 1900-1-1
NETCDF_VARNAME=pet
units=mm
Band 2 Block=720x1 Type=Float64, ColorInterp=Undefined
Metadata:
NETCDF_DIMENSION_time=410
NETCDF_VARNAME=pet
units=mm
Band 1308 Block=720x1 Type=Float64, ColorInterp=Undefined
Metadata:
NETCDF_DIMENSION_time=40161
NETCDF_VARNAME=pet
units=mm
