[GRASS-user] two questions - v.overlay and r.to.vect
Carlos wrote:
1 - v.overlay: can we make it to run also with points data?
That is, I want to "clip" extract some vector points using a
polygon as limit. So far it seems to work only with lines
(6.5svn)
use v.select
2 - r.to.vect: It would be nice if we could select which
features to be converted to vector by its categories,
perhaps use r.mask or r.reclass first for the filter?
Hamish
