I am using following Python code to add all raster maps with wildcard name: viewshed*.
grass.run_command (“r.series”, input="g.mlist pattern = 'viewshed*' sep =, ", output = ‘xx’, method = ‘sum’)
But it does not work saying:
WARNING: Illegal filename <g.mlist pattern = 'viewshed*' sep =>. Character < > not allowed. ERROR: Raster map <g.mlist pattern = ‘viewshed*’ sep => not found
What is the possible error? I am using GRASS in Windows7
2013/1/10 Brian Sanjeewa Rupasinghe <jinkabs@gmail.com>:
grass.run_command ("r.series", input="`g.mlist pattern = 'viewshed*' sep =,
`", output = 'xx', method = 'sum')
you cannot use bash-like constructions in Python script. Try
maps = grass.mlist_strings(type = 'rast', pattern = 'viewshed*')
grass.run_command ("r.series", input = maps, output = 'xx', method = 'sum')
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Many Thanks Martin. It worked fine.
Cheers, Brian
On Thu, Jan 10, 2013 at 6:55 PM, Martin Landa <landa.martin@gmail.com> wrote:
maps = grass.mlist_strings(type = ‘rast’, pattern = ‘viewshed*’)
grass.run_command (“r.series”, input = maps, output = ‘xx’, method = ‘sum’)
Martin
