Hello,
Trying to use the georeferencing tool in 6.4.1, I have the following question: is it possible to define a vector map as target map when georeferencing a raster map ? I can't seem to find how to do this.
Moritz
Hello,
Moritz
On 27/10/11 21:10, Moritz Lennert wrote:
Hello,
Just to be precise: I'm talking about the tool in the wxgui.
Am I the only one seeing this as a problem ? I can work around this by transforming my vector map in a raster and then use the result as target map. But I find this less than ideal. It should be possible to use vector map as reference, not only raster maps.
I will file a bug report about this, but was just wondering whether I'm missing something obvious.
Moritz
On Sat, Oct 29, 2011 at 11:25 AM, Moritz Lennert
Hello,
georeferencing a raster map ? I can't seem to find how to do this.Just to be precise: I'm talking about the tool in the wxgui.
map as reference, not only raster maps.I will file a bug report about this, but was just wondering whether I'm
Vector support in the georeferencing tool is poor. Ideally the tool
would have something like a layer manager where you can add as
reference maps any number and combination of raster and vector maps,
just like in the regular layer manager. Further more, the C module
v.rectify is still missing (I want to write it based on v.transfrom
and v.proj but did not get around yet to do it).
Markus M
<mlennert@club.worldonline.be> wrote:On 27/10/11 21:10, Moritz Lennert wrote:
Hello,
missing something obvious.Vector support in the georeferencing tool is poor. Ideally the tool
Ok, so currently I have to use the v.to.rast workaround, then. But does the solution really have to be a whole layer manager ? Generally one does not use many different layers as reference maps, so just having a choice between vector and raster reference maps in the preparatory steps of the tool should be enough IMHO.
v.rectify is still another issue. v.transform probably covers most of the use cases anyway, or ?
Moritz
On Mon, Oct 31, 2011 at 11:22 AM, Moritz Lennert
Hello,
and v.proj but did not get around yet to do it).Ok, so currently I have to use the v.to.rast workaround, then. But does the
be enough IMHO.
OK. Then the option for reference maps could be one raster map and/or
one vector map (vector map always on top of raster map).
Yes, apart from the case when source and target LOCATION_NAME are
different. This is handled by v.proj. Since GCPs are specific for a
given source / target location combination, a TARGET like for imagery
groups would also be needed.
Markus M
Hello,
be enough IMHO.OK. Then the option for reference maps could be one raster map and/or
This sounds good to me.
use cases anyway, or ?Yes, apart from the case when source and target LOCATION_NAME are
I think that in many cases you can import the data directly into your target location and run v.transform there. This is less the case for raster data. But I agree that the possibility should be there for the user to georeference vector data between two different locations.
Moritz
On Mon, Oct 31, 2011 at 1:27 PM, Moritz Lennert
Hello,
target
vector
the
between
should
one vector map (vector map always on top of raster map).This sounds good to me.
groups would also be needed.I think that in many cases you can import the data directly into your target
I have added full vector support in the wx georectifier (trunk
r50059). You can now display a vector and/or a raster from the target
location, and the long-standing bug [1] for vector rectification is
also fixed by using the new module v.rectify.
Markus M
