[GRASS-user] Using d.vect in python script
It's my first grass python script using all the bells and whistles
(g.parser gui construction and the grass.run_command) so I might be
asking something silly.
Can I use d.vect and d.rast commands in python script so that the map
is displayed in the GUI? I'm running the grass script inside the
command console window.
For instance, if I type:
d.vect munic
in the command console, the munic vector is displayed in the GUI but,
if I put grass.run_command("d.vect", map=munic) in a python script and
run this from the command console, nothing happens.
Thanks for the help
Daniel
d.vect munic
The GUI has a hack where commands beginning with "d." are treated
specially.
If your script name begins with "d.", you may be able to get it to
work with your script. Otherwise, the correct way to display the
output from a script in the GUI is to add a new command layer.
Either way, if the script executes multiple display commands, you
need:
  os.environ['GRASS_PNG_READ'] = 'TRUE'
after the first command in order to have subsequent commands render on
top of previous commands. Otherwise, each command will clear the
image, and you'll only see the result of the last one.
