[GRASS-user] using mapcalc in a python script
I am working on converting a shell script to python and ran into a problem I haven't been able to figure out using the r.mapcalc command. Can someone let me know how to write the following command using python. The command creates a GRASS MASK layer:
r.mapcalc "MASK=if(($cloudResampName < 0.01000),1,null())"
I'm trying to run the python script using GRASS 6.40RC6 (2010).
All the best,
Ned
  import grass.script as grass
  grass.mapcalc("MASK=if(($cloudResampName < 0.01000),1,null())",
                cloudResampName = cloudResampName)
The first argument to the mapcalc function is a template (see the
Python library documentation for string.Template). Any keyword
arguments (other than quiet, verbose or overwrite) specify
substitutions.
