I'm making progress translating my shell script to Python but ran into another stumbling block. I would like to convert the following shell script command to the python scrip:
v.out.ascii $randomName fs=' ' | r.what input=$resampName> $pointTableName
I tried various combinations of grass.pipe_command and grass.feed_command but haven't been able to get it to work.
Any help would be appreciated.
Ned
Using pipe_command() and feed_command() will give you two pipes (one
each), but you only want one. Use start_command():
outf = file(pointTableName, 'w')
p1 = grass.pipe_command('v.out.ascii',
input = randomName,
fs = ' ')
p2 = grass.start_command('r.what',
input = resampName,
stdin = p1.stdout,
stdout = outf)
outf.close()
p1.stdout.close()
p1.wait()
p2.wait()
start_command() is the most general function; all of the others
(except exec_command()) end up invoking start_command().
Hello,
since some weeks I have the libgdal-package in my Ubuntu (Karmic) update manager, listed under ‘distribution update’ (Distributionsaktualisierung) but I can’t update it.
Now I tried to install this package from lauchpad.net: libgdal1-1.6.0-grass_1.6.2-3_amd64.deb
The result is this absent dependency expression: “Fehler: Abhängigkeit kann nicht erfüllt werden: grass640-5+39438” The GRASS version I’ve installed is 6.4.0RC6. Asks the expression […]grass640-5[…] for version RC5?
Regards and thanks for a clue,
Benedikt
On Mon, Jul 5, 2010 at 9:39 AM, Benedikt Ziegler
<benedikt.ziegler@gmx.de> wrote:
Hello,
manager, listed under 'distribution update' (Distributionsaktualisierung)
but I can't update it.
The result is this absent dependency expression: "Fehler: Abhängigkeit kann
nicht erfüllt werden: grass640-5+39438" The GRASS version I've installed is
6.4.0RC6. Asks the expression [...]grass640-5[...] for version RC5?
Looks like that - perhaps it should have been written as >= grass640-5+39438?
I think that you need to open a bug report in launchpad.
Am 05.07.2010 20:21, schrieb Markus Neteler:
Hello,
Looks like that - perhaps it should have been written as>= grass640-5+39438?
A view in Synaptic package manager shows that there is libgdal1-1.6.0-grass AND libgdal1-1.7.0-grass installed on my system. Is the older version obsolete and can completely uninstalled instead of updating?
Benedikt
