Hello Sir/Ma’am,
Warm Greetings.
I am Omkar Kadlag from Mumbai,India.I am pursuing Electronics and Telecommunication Engineering majors from K.J.Somaiya Institute of Engineering and Information Technology,Mumbai. I am working on a project “Watershed Analysis using python”.
While using GRASS GIS python console for analysis, I’m unable to get desired results. While giving the input ( as a DEM tile ) in the PowerShell prompt of GRASS GIS Software, it gives an error, as ‘wxpython file’ is not available.(The error image is uploaded with this mail). Then I made a new environment in the anaconda prompt, where I installed ‘wxpython’ and was successfully able to run GRASS GIS software, but now the issue is I can’t use the command prompt for my analysis. Then I tried to give inputs in the anaconda command prompt but was still unable to get correct outputs (the error image is uploaded with this mail). I want solutions where I can run GRASS GIS directly from the command line and implement my solutions on that.
Yours Sincerely,
Omkar.
(attachments)
